- Mercedes-Benz C-Class: How to Install Illuminated Star Grille Emblem
Step by step instructions for do-it-yourself repairs
Browse all: Exterior Guides
Illuminated star fitted.
Basically I am torn whether to do a full blacked out 507 style grille or not. However, if I purchased one that was all black like what's offered online, can't I just swap my factory grille's star over if I decided later to go that route?
If so then I will just buy an all black and see which one I prefer once all the chrome is removed from the vehicle.
so if you follow the installation instructions, this will work on a prefacelift c63...
i'm a little confused with the always on talk... if you connect it to you parking lights... it will only be lit at night right? and nothing will happen when you lock and unlock the car... but if you connect to SAM, whoever the heck that is, it will go on and off and always be on at night?
any of these options also make it always on during the day other than hooking it up to the DRL? i have drl off on my car
i don't think it will fit a pre-fl grill. I think the pre-fl star would twist to remove. the fl illuminated star is held in by 3 tabs.
if you connect it to the parking lights, it will be on only with the parking lights. is this a serious question?
the SAM is a logic controller for the vehicle. the "by the book" installation of the star includes a SAM module to plug into the vehicle SAM so the star can be controlled by the vehicle "computer". This allows whatever functionality your vehicle is programmed for, which by default is something like always on while driving, 1 min after unlock, and 1 min after parking. In Canada the module is programmed differently because a 3rd front light is not road legal.
you can make it always on by finding a ignition wire, splicing it to a relay which turns on your star.
i run mine by splicing my parking light. it is literally two wires, one from my parking light, and a ground. the star turns on to full brightness whenever the parking light turns on, which is unlock/lock, driving with low beams on, or switching to parking lights + DRLs.
Generally I just don't recommend doing the SAM module at all, because it is twice the cost of just the star, and gives no benefit.
I've been running the star spliced to my parking light for over a year with no issue. It's a no brainer. The star doesn't require any complex circuitry, it's literally just a 12v accessory.
king lights.
i was thinking of buying the grill from 55tech and maybe do this illuminated star mod...
oh well...
I've been down this path before, I asked 55tech as well as every ebay seller I could find that sells 2012 C-Class grilles asking them for the model number of the star they use. They all use W163 ML-Class stars. Illuminated stars exist for W166 ML-Class, but they are a different size.
The only grills that will house a factory W204 illuminated star are the FL C-Class grille (3 fin), and the FL C-Class Coupe grille (2 fin)
Another if I use add a fuse to fuse #23 as someone here mention. Does the result still same? I mean led light will always on.
When you turn your Light switch it should turn on your Parking lights, Running Lights and the Star. Second position should add your Low beams.
What I've done was hooking the red wire (+) with a fork-type connector to the parking light's female plug and grounded the black wire (-). There wouldn't be a problem because it draws little power.
Be careful one day your Front Sam may working not properly because normally it random check how voltage different than normal bulb. if you are luck it will fine.
I dont want to connect to fuse 23, as the star stays on even if the parking lights are off.
I really like it, so I am thinking of butchering the existing tabs of my aftermarket grille to make the illuminated star and the base fit and then look at the option of securing it with screws (or something) from the back.
This is the grille I have:
