Old Jun 10, 2015, 06:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Diagnostics
Print Wikipost
2012 C250 Engine noise.
Old Mar 11, 2014 | 02:23 PM
arketect's Avatar
2012 C250
I was wondering if anyone on here is experiencing an engine noise from the 1.8 turbo motor. Seems to be mainly when cold/start up. Sounds like very loud fuel injectors. From upper engine area. After warm up, quiets down a lot. Was hoping for some type of suggestions prior to having it services at BM Dealer. Also, no MIL light or performance changes. In car - unnoticable, only from outside.
Old Mar 11, 2014 | 09:18 PM
MDMercedesGuy's Avatar
2024 GLS450
Mines pretty quiet all of the time - even on a cold startup.
I know the M271 Kompressor engines have some timing chain issues they are prone to, but not sure about the M271 Evo that we have.
Hopefully Glyn can chime in - I seem to remember he was the one that knew about the chain issues on the older 271s.
Old Mar 12, 2014 | 03:42 AM
Glyn M Ruck's Avatar
Super Moderator
The DI engines have distinctive sound. Slightly diesel like & normal.
Make sure you have the latest ECU flash next time you service.
Otherwise can be a lazy hydraulic lifter.
The chain noise is front of engine. Rattle at cold start that shuts up as oil pressure comes up. If you ever hear this rattle pull a new chain with use once tensioner element immediately.
Old Mar 12, 2014 | 05:56 AM
gmphertford's Avatar
S Class
Hi there The noise is from the camshaft adjuster, common on that engine, they get stuck, take to garage to get checked, will need replacing. Changed them before because of this.
Old Mar 12, 2014 | 06:56 AM
arketect's Avatar
2012 C250
Smile
Appreciate the response. Will be taking it in next week. We'll see what dealer says.
Also, definitely sounds like the top of engine. Not the front. Hope that eliminates any timing concerns.
Old Mar 12, 2014 | 10:57 AM
Super Moderator
A burred camshaft adjuster can sound very like the chain. It rattles at cold start & shuts up as oil pressure rises. Not very common on newer M271's & derivatives.
There is a deburring procedure that never works. Replacement is all that works.
It's likely just DI noise. They multipulse the injector to make it as quiet as possible.
Old Mar 12, 2014 | 11:07 AM
2024 GLS450
It seems that as the miles have been put on, the DI noise has gotten quieter on my car. I'm at 23K now, and it is very quiet at idle with no clatter.
Old Mar 12, 2014 | 11:43 AM
Super Moderator
MDMG ~ Have they ever reflashed your ECU? There was a bit of playing with tuning on early DI cars. Changing injection can reduce & flatten that sharp pressure rise that sounds a bit like minor knock. I'm also convinced that there is a little bit of exhaust system effect after the exhaust has seen some use.
Old Mar 12, 2014 | 11:47 AM
2024 GLS450
Yep - I'm currently running the latest flash. They installed it back when I kept having the single misfire events. I haven't had any more of those, and there was a drivability change (the engine seems much less peaky).
I have noticed more carbon on the exhaust tip between detailings, though. I can deal with that - particularly since after going over everything with a boroscope I did not have any carbon buildup on the intake side of the house or valves.
Old Mar 12, 2014 | 01:41 PM
Super Moderator
Suggest the OP ensures he has the latest ECU flash.
Old Jul 19, 2014 | 01:33 PM
que4dog's Avatar
2012 c250
How difficult is it to change the timing chain adjuster?
Old Feb 6, 2016 | 12:18 PM
que4dog's Avatar
2012 c250
bump
