Randomly cannot throttle past 2500RPM
Old Apr 26, 2014 | 04:23 PM
sameerabbasi97's Avatar
08 C300
Exclamation Randomly cannot throttle past 2500RPM
My 2008 C300 will randomly (like once every week or so) make a shifting noise and I couldnt throttle past 2500 RPM (which is fun when crossing intersections). When this happens I get no lights except that D C/S gets un-selected on the screen (while the car still can drive). A restart of the engine usually resolves the issue temporarily.
This happens regardless of C/S settings and I've reset my ECU twice to no avail.
Here is what it looks like at the max RPM (I took this picture today):
Sorry about the strange orientation. Its hard taking a photo at 50mph!
What could possibly be going on?
Old Apr 27, 2014 | 01:23 AM
mmike's Avatar
'10 C300
strange that your gear selection is not highlighted...
Old Apr 27, 2014 | 08:22 AM
mflores342's Avatar
2014 C350 4M Sedan , 2014 GLK350 4Matic
Sounds like the throttle position sensor is on the way out. I believe the 2500 rpm is the fail safe default to be able to get the car moving to a safe location vs. getting stuck.
Old Apr 27, 2014 | 06:15 PM
acr2001's Avatar
2012 C300 4Matic
Because of the gear selection missing (as someone noted), I doubt it is your throttle position sensor (which is otherwise the best guess). Sounds like some other electrical gremlin. Needs to be diagnosed at the dealer, or someone with star.
Old Apr 27, 2014 | 07:50 PM
08 C300
Ah, thanks guys! I've been avoiding taking this thing to the dealer for so long because its so far away but I guess I gotta take the trip.
Old May 19, 2014 | 09:12 PM
08 C300
For anyone that may experience the same issue: I took this to the MB dealership and they replaced the sensor along with the transmission valve body.
Old May 20, 2014 | 11:24 AM
vipsa's Avatar
'09 C350
Whoa, that sounds like overkill, unless they had diagnosed a bad valve body. Did they tell you why they had to replace the valve body? Also, can you tell us if your car had the trans fluid changed at the 40k mile interval.
Old May 20, 2014 | 08:13 PM
08 C300
I believe they did diagnose it as the valve body going wrong. I doubt that they were faking it because an adjuster from our extended warranty had to come to see it before they paid out (a grand total of 2100 dollars).
I bought the car used (after 40k) so I have absolutely no idea if they changed the fluid, but they did change the fluid during the repair.
Old Jun 3, 2014 | 02:33 AM
Mr.Mango's Avatar
2009 C300 4Matic
Your vehicle was going into limp mode, which limit rpm and allow 1 gear. Hense the name!
Could be a faulty shift solenoid or TPS. Shift solenoid can be replaced individually but you have to take the valve body off on W204 to get any of them off. So likely said screw it, its warranty R&R as a unit haha
Old Jun 8, 2014 | 02:55 PM
ncglock's Avatar
E63
Bad pedal sensor
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
