- Mercedes-Benz C-Class: How to Remove Steering Wheel
Step by step instructions for do-it-yourself repairs
Browse all: Interior Guides
DIY - FL steering wheel swap
You can find a few steering w/airbag on ebay or you can part it out like I did which saved me more $.
These are what I've purchased:
Steering wheel A172 460 2803. There was also 9E38 written after the part # on the steering wheel but not sure what they mean. It was taken off a CLS according to the seller.
Airbag
Description of the airbag was:
AMG airbag for C C63 CLS 63 E63 CLK SL W204 W218 W207 R231. AMG ONLY! This is important. Non AMG airbag is for a 4 spoke steering and will not fit. Thanks to MDMercedesGuy for pointing this out to me.
UPDATE
It looks like there are 2 type of amg steering wheels. I bought steering wheel 1 below but with airbag 2 so there's a gap on the bottom which I can live with. I've also seen some selling steering w/airbag in this setup so pay close attention to the images they provide or ask them a question if you're unsure.
So please consider the following:
If you buy this steering wheel w/o airbag
Attachment 376468
Then buy this airbag
Attachment 376469
Attachment 376470
If you buy this one w/o airbag
Attachment 376471
Then get this airbag
Attachment 376472
Attachment 376473
Either one you buy make sure the airbag has this connector included. You will have a hard time finding one of these otherwise.
Attachment 376474
***Again if you buy a complete set, still pay attention to the airbag as I've seen some still with wrong airbag.
So lets get started with the swap
Tools I used:
T30 torx
10mm socket set
10mm allen wrench
Attachment 376475
Now lets get started!
The battery is located under the air cabin filter box under the hood. It has 3 snap on clips. 2 on the sides and 1 center.
Attachment 376476
I forgot to take a picture of this one but this one shouldn't need it. But once the battery is exposed, use the 10mm socket wrench to remove the negative terminal from the battery and make sure to put something in between the negative terminal and negative post on the battery so they don't touch. I used rubber gloves. If you don't disconnect the battery you will get an airbag error which only the dealer or Mercedes tech can clear. So do not skip this step.
Now for the steering wheel removal.
Turn the steering wheel left and so the steering locks. This will be useful later.
Locate the steering mount holes located on the back of the steering. There’s one on the left and one on the right side. Use the T30 torx screw to loosen both torx screws all the way.
Attachment 376477
Slowly lift off the airbag from the steering wheel so you don’t accidentally yank on the airbag and steering cables.
You will see these 2 connectors on the steering column (brown & yellow). Hold the airbag or have someone hold it for you while you remove these connectors.
There are 2 tabs you need to push in to unlatch the connectors and then just pull the connectors straight out.
Attachment 376478
Once the original airbag is removed, you will have better access to the bolt that holds the steering.
Attachment 376479
Remove the center bolt using the 10mm allen wrench. It might help if you use the socket wrench you used earlier for the battery as a lever. Long end of the allen goes to the steering bolt, while the short end connects to the socket wrench.
Attachment 376480
And unscrew that sucker. Remember earlier, you made the steering lock. This is where it's useful if you don't have any to help or tools to hold the steering wheel. Now give it all you’ve got! It will be tough to remove but I didn’t give up. Just make sure you are pushing on the allen wrench at the same time so you don’t slip or end up stripping the bolt. Sorry I was working solo on this one so I couldn’t take a picture as I was trying to remove the bolt and didn’t want to drop the tools into the steering and scratch it.
Once the bolt is removed, pay attention to the marker inside. When you put your new steering wheel, it has to line up the same way or your steering will be off centered.
Attachment 376481
Time for the new FL Steering wheel
Put the steering wheel on and again make sure you line it up exactly how the old one was. I recommend you use lock tite on the bolt. Put the bolt back on. Make sure the bolt is on there tight!
Reattach the brown connector from the steering.
Grab the new airbag and attach the yellow cable to the steering column. Tug on both wires to make sure they are clipped in good and won’t come off.
Line up the airbag and just press it in till you hear the left and right side click in place.
Reattach negative terminal on the battery.
Enjoy your new steering wheel!
Attachment 376482
Attachment 376483
*** The paddles shifters worked on the new steering wheel for me even though my stock steering didn’t have them. Not sure this is true for all cars. So YMMV on this one.
W204 upgrade FL steering paddle shifter works - YouTube
I did a FL steering wheel swap on my 2010 C63 and nothing on the new wheel worked I thought my clock spring could be damaged so I put the stock wheel back on and it worked just fine any idea why btw wheel is from a 2013 C63
After saying that. well...
A few days ago i buyed a 3 spoke steering wheel "sport version with rounded bottom and rounded upper part that include paddle shifters.
Currently i have installed on my W204 FACELIFT C180 the 4 spoke version with no paddle shifters.
On my stupidity i tought that the airbag from the 4 spoke Steering wheel will fit the 3 spoke steering wheel. But, according to what ive been reading from all of you, the airbag will not fit.
I want it to know, if the swap from the 4 spoke to the 3 spoke will work or not please, im only interested in the fitting, i mean if theres a gap i can live with it...but if not fits at all ... im gonna have to buy the new airbag that fits correctly.
Thanks for your time.
I know this thread is quite old now, but i would still like to try...
So will it be possible to swap the original 4 spoke prefacelift steering wheel to 3 spoke amg steering wheel? Will it be plug and play install?
Will the paddle shifters work on my 7-speed automatic transmission?
These are the parts im willing to buy:
https://ovoko.fi/osat/jul16253-merce...ran-turvatyyny
https://ovoko.fi/osat/nar147-mercede...12-ohjauspyora
From this
to this
with this airbag
