Advice needed: All season or grand touring tires for fourmatic?
Old May 11, 2014 | 09:47 PM
stratman1954's Avatar
2012 C300 sport
I will be needing new tires for my c300 sport fourmatic soon. I am more interested in a smooth, quiet ride and long tread life than anything else. Living in N.J. we get 5 or six snowstorms over 6 inches every winter. Will grand touring tires be a lot worse in the snow then all seasons?
Old May 11, 2014 | 09:59 PM
Sportstick's Avatar
Another round of ICE
Neither type of tire will be adequate in those winter conditions. I am hoping you were not lead to believe that all-seasons actually are winter-capable, nor that all wheel drive is a viable alternative to winter tires. The tires are far more critical to winter driving safety than having all wheel vs rear wheel drive. You might be best off with grand touring tires such as Michelin Primacy MXM4 for three seasons, but then acquire Bridgestone Blizzak WS70 or Michelin XIce xi3 for the winter.
Old May 11, 2014 | 10:21 PM
2012 C300 sport
I made it through an unusually bad winter last year with tires that have 27k miles on them and actually made it through the snow fairly easily. So what I'm actually trying to do is get a softer, smoother ride and was led to believe grand touring tires would achieve that over all-seasons. So I'm wondering if all seasons and grand touring give similar performance in snow.
Old May 11, 2014 | 10:35 PM
Sportstick's Avatar
Grand touring tires, such as the one I mentioned, will be quite quiet and soft. As for getting through last winter, you were lucky. Yes, you were able to get the car moving, but had you needed sudden braking or turning to avoid a crash, your outcome would be dramatically different with either of those vs winter tires. As to whether either kind of less-capable tire is worse than the other is a "lesser of evils" discussion. Neither can be recommended in good conscience, considering the potential of a winter loss of control/crash. Check the snow test results on Tire Rack for the specific tires you are considering.
Old May 11, 2014 | 10:39 PM
2012 C300 sport
Good advice Sportstick, thanks. Now that you mention it I wasn't in any panic situations.
Old May 12, 2014 | 03:04 PM
TheRulesLawyer's Avatar
C350
Grand touring is more of a performance level than all season vs summer. Typically a grand touring tire will be all season, but its a softer ride quality prioritized type of tire. As others have said, you are far better off buying winter tires if you live somewhere where it regularly gets snow. Even without snow a dedicated winter tire will have better traction below about 45 degrees than an all season due to the material not getting hard in colder temperatures.
Old May 12, 2014 | 06:20 PM
malahhaor's Avatar
06 Carrera4
+100, no sub for winter tires.
I like Conti DWS for summer and will help in the first light snow of the season if you didn't change to winters in time. but then run dedicated winter setup.
If you have no traction (which winter tires are better at in cold temp and snow weather), no amount of wheel drive, 4 or 16 will help you to stop if you slam on those brakes or have to swerve.
you'll hear people argue that with AWD one tire or two will always have grip in real world driving, or you can slow down better using engine braking, or you can turn easier yata yata yata.... everyone has their own way of driving and their opinions and its all BS in my opinion because of a simple fact is that grip between tires and the road what matters the most. Having AWD is a big bonus but not the solution.
Old May 12, 2014 | 07:01 PM
Sportstick's Avatar
I think we have a consensus developing!
