Harmon Kardon System Question
Old 05-31-2014, 06:29 PM
ID1
ID1's Avatar
c350
Hello All,
I recently took my car in to the dealer fix the rear deck rattle on my 2011 C350 with Harmon Kardon System. When I got the car back the rattle was gone, but the bass was significantly reduced as well. I want to know if anyone with a Harmon Kardon system can help me out with my theory, as I suspect the stealership simply disconnected my subwoofer and any remaining bass I am hearing is coming from the rest of the system. I ran a quick test where I faded the audio to the front 2 speakers to see if the subwoofer in the rear would still remain on, and it does not. When I fade the sound to the rear of the car, I cannot tell if it is the subwoofer that is producing the bass or if its only the remaining speakers playing in the rear that output the bass. In a home theater system, regardless if the system is faded to the front or the rear, the subwoofer is consistently on, but I do not know if it is the case with our cars. Any responses would be greatly appreciated. Does your rear sub remain on if you fade the audio to the front of the car? Thanks.
Old 06-01-2014, 04:24 AM
Gashde's Avatar
C220 W204
Try turning on the "Bass" to 10 and "Treble" to -10. You should be able to hear the sub more accurately this way, if there's hardly any pounding even with high volume then the dealer must've performed half a job.
Old 06-01-2014, 12:41 PM
ickdeep's Avatar
'13 M5 | 08 C300 (Sold)
If you got it done by the dealer and it doesn't work. Go back there and tell them to fix it. You made them already to "fix" it and if it wasn't done correctly, you make sure it gets done correctly now.
Old 06-01-2014, 01:20 PM
ign92's Avatar
2008 C300 4MATIC
Question, how much did the stealer charge you to fix the rattle?
Old 06-01-2014, 01:47 PM
MBc300elvis's Avatar
C300
Hahaha
Old 06-01-2014, 11:46 PM
ID1
ID1's Avatar
c350
Car was still under warranty, my cars warranty expires soon, I want to take care of this soon.
Old 06-03-2014, 01:47 AM
ID1
ID1's Avatar
c350
Has anyone been able to try this?
Old 06-03-2014, 02:14 AM
Mr.Mango's Avatar
2009 C300 4Matic
Attempt what Gashde said, but dont fade to the rear. Cause the Subwoofer doesnt fade with the speakers.
If its still not working just take it to the dealer... its under warranty for a reason. Quite possible they disconnected the sub in order to fix the rattle and forgot to plug it back in.
Old 06-03-2014, 11:45 AM
ID1
ID1's Avatar
c350
Ok will try it today, since u said the sub doesn't fade with the speakers, I I fade it to the front, the sub in the back should still be firing?
Old 06-03-2014, 01:02 PM
Gashde's Avatar
C220 W204
I just tested out the system with - Like a G6
Moved around with the settings, basically when +10 forward and -10 on the treble, +10 Bass, there's no sound playing from the rear speakers EXCEPT for the bass of the music, basically you can not completely eliminate the bass however you position the sound.
What I find is air being blown out of the rear speakers, I presume its from the subwoofer, you will feel the vibration and forced out air if you place your hand over the speakers behind the rear headrests.
Hope that helps
Old 06-04-2014, 01:43 AM
ID1
ID1's Avatar
c350
Smile
http://youtu.be/GvgJEznqtms
Hope that helps
Thank you for taking the time to test this, I tried it myself and there is indeed air coming our from the sub. I guess maybe they did such a good job insulating and tightening everything back there, that it doesn't vibrate and rattle anymore, making it seem like there is less bass. Thanks for your help!!!
Quick Reply: Harmon Kardon System Question
