Facts about Tranny fluids
Old Jul 7, 2014 | 09:19 PM
Seraphim's Avatar
2013 C207 E550
Hey guys, i've been reading a few posts about swapping out Tranny fluids for my w204 at 30k miles, is this a MB recommended procedure or is this like an urban legend type of deal. I've spoken to my mechanic and he told me not to do it as it might expend some of the seals inside the tranny. i need some facts here. Thanks for the help!
Old Jul 7, 2014 | 10:32 PM
Uncle's Avatar
2010 C300
I did mine at about 50K miles. The fluid was a little discolored, smelled fine, and the magnets in the pan had a light coating of particles. Nothing to be concerned about. It is an easy job if you don't allow yourself to get overly caught up in some of the procedures.
Jack it up, put it level on four stands, remove the belly pan, drain the fluid from the plug, remove the pan, remove the filter. wipe off the magnets, use a new filter, new bolts, new nipple,new gasket an re-assemble. Pump fluid in until it overflows, run the engine until the pan is warm to the touch, around 110 degrees F, add more fluid, when it stops running out ,replace the plug.
Old Jul 8, 2014 | 02:07 AM
Seraphim's Avatar
2013 C207 E550
but is it a recommended operation or is it something we(community) thought should be done
Old Jul 9, 2014 | 02:50 AM
Seraphim's Avatar
2013 C207 E550
bump?
Old Jul 9, 2014 | 04:27 AM
Knightmare69's Avatar
2010 C200 CGI
Have you checked your manual? I thought they revised the manual from lifetime fluid to interval change? As I said in another thread, I do it yearly just for peace of mind, it's not really expensive and it's preventative maintenance for me.
Uncle, I take it you don't have the 7g since your procedure didn't mention the TC drain?
Old Jul 9, 2014 | 10:55 PM
Uncle's Avatar
2010 C300
Sorry, I did pull the plug on the TC. Easy to do. I drained a total of 8.5 by measure.
Old Jul 9, 2014 | 11:41 PM
Seraphim's Avatar
2013 C207 E550
it would still be the same procedure if mine is a 4matic, correct?
Old Jul 10, 2014 | 09:53 AM
screw991le's Avatar
2010 E63 AMG
Sub'd waiting for more opinions.
Old Jul 10, 2014 | 03:34 PM
Glyn M Ruck's Avatar
Super Moderator
Lot's of crap spoken on this subject. Unless you have a 722.9 Plus you should change the fluid & filter every 39K miles or 60K Km's for long transmission life.
Use only 236.14 approved fluid.
Old Jul 11, 2014 | 12:01 AM
Seraphim's Avatar
2013 C207 E550
whats a 722.9?
Old Jul 11, 2014 | 01:23 AM
2010 C200 CGI
Originally Posted by Seraphim
whats a 722.9?
722.9 is the 7G tranny, if you have the 5g then it's 722.6.
Old Jul 11, 2014 | 01:36 AM
screw991le's Avatar
2010 E63 AMG
I am going in for B3 service and a tranny flush along with a long list of stuff needs to be done. I have 4 years and 30000 miles on her.
