Can you help identify this belt?
Old Aug 11, 2014 | 01:57 PM
ah526's Avatar
c300
One of my belts on my '08 C300 Sport 4-matic is shredded. See photo of belt.
What part number is this? Looking to identity the belt and order online.
Anyone know how long it would take a local garage to install this belt?
Old Aug 11, 2014 | 04:04 PM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
should take about less than 15 mins to install.
it is the serpentine belt
Old Aug 11, 2014 | 04:19 PM
itsLoonie's Avatar
2012 E350 RWD
Like shardul stated, it is a serpentine belt. You should be able to find this at any local auto parts store. Brand you have in it now should be a Gates which the stores should carry. Oreilly Auto Parts carries these belts for around $35 + tax.
Old Aug 11, 2014 | 04:50 PM
JPc300's Avatar
C300
FYI, check all your pulleys. That's not always but usually a sign the you might have a bad pulley.
Old Aug 11, 2014 | 05:57 PM
ah526's Avatar
c300
Thank you all. Always impressed with the knowledge in this community.
Old Aug 11, 2014 | 07:56 PM
ah526's Avatar
c300
Does the c300 sport use a 6 Rib?
I am going to purchase at this my local Auto Zone store but they have many different ones. See list. Not sure which one is best choice.
Old Aug 11, 2014 | 08:33 PM
GATORB8's Avatar
2012 C300 4Matic Sport, 2006 Ford F150 Lariat 4x4 5.4L
Did you add "my vehicle" to filter for yours?
It shows 3 options (different brands) with that in:
Dayco Serpentine/Belt
Part Number: 5060945
Warranty: 3 YR
Notes: Main drive
Price: $32.99
Duralast Serpentine/Belt
Part Number: 945K6
Alternate Part Number: 945K6
Warranty: 1 YR
Price: $28.99
Valucraft/Belt
Part Number: 945K6
Price: $24.99
Rockauto is another good source for part number, here is what they show:
2008 MERCEDES-BENZ C300 3.0L V6 : Belt Drive : Belt
Economy
ROADMAX Part # 6K945AP Automotive V-Ribbed Belt (Standard); K06 13/16" x 95 1/8" (Only 12 Remaining)
$8.13
DAYCO Part # 5060945DR {#6PVK2400, 945K6} DriveRite
Main Drive
$10.31
BANDO MFG. Part # 6PK2400
Serpentine Belt; 4 WHEEL/ALL WHEEL DRIVE,RIB ACE PRECISION ENGINEERED V-RIBBED BELT - 4MATIC LUXURY - 4MATIC SPORT - MAIN DRIVE - GAS Engine - INCH NUMBER: 945K6; LUXURY
Choose:
$12.51
BANDO MFG. Part # 945K6
Serpentine Belt; OEM: 19931896; LUXURY
Choose:
$12.51
Standard Replacement
GOODYEAR Part # 4060945 Gatorback; Poly-V; 6 Ribs / Effective Length 94.5" / Outside Length 95.25" One of our most popular parts
Accessory Drive; Poly-V
Part Image
Choose:
$11.93
DAYCO Part # 5060945 Poly Rib Belt, Premium; Exceeds OE Specifications Effective Length 94.50 / Top Width .82 / No of Ribs 6 / Thickness 0.169 One of our most popular parts
Main Drive
$18.80
GATES Part # K060945 {Click Info Link for Alternate/OEM Part Numbers} Micro-V AT Premium OE V-Ribbed Belt; K06 13/16" x 95 1/8"
$21.79
FLENNOR Part # 6PK2403 {Click Info Link for Alternate/OEM Part Numbers} Automotive V-Ribbed Belt (Standard); Material: EPDM (Ethylene-Propylene-Diene-Terpolymer)
Flag indicates this part fits vehicles sold in the European Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide. Driven unit: alternator; Manual Transmission
$26.79
FLENNOR Part # 6PK2390 {Click Info Link for Alternate/OEM Part Numbers} Automotive V-Ribbed Belt (Standard); Material: EPDM (Ethylene-Propylene-Diene-Terpolymer)
Flag indicates this part fits vehicles sold in the European Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide. From 10/2008; Driven unit: alternator; Automatic Transmission; , 08/2009, 10/2009; From Chassis No.: L, F, A, R; Model: 7G Tronic (Only 13 Remaining)
$26.79
ACDELCO Part # 6K945 {#88932790} Professional; K06 13/16" x 95 1/8"
Old Aug 11, 2014 | 08:46 PM
ah526's Avatar
c300
Yes I added my vehicle but it displayed various ribs. I think it's 6 but wasn't sure. Any suggestions on the ones you listed is appreciated. I'll just pick one based on your input. Which one would you order?
Warranty: 3 YR
Notes: Main drive
Price: $32.99
Part Number: 945K6
Warranty: 1 YR
Price: $28.99
Valucraft/Belt
Part Number: 945K6
Price: $24.99
Economy
$8.13
Main Drive
$10.31
Choose:
$12.51
Choose:
$12.51
Part Image
Choose:
$11.93
Main Drive
$18.80
$21.79
$26.79
$26.79
Old Aug 11, 2014 | 09:13 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
Count the ribs, any belt will be better than the one you are running now, check pulleys for excess wobble and replace if they spin for a long time when flicked with your finger.
Old Aug 11, 2014 | 10:08 PM
ah526's Avatar
c300
Thanks. I counted 6 ribs. Where are these pullys you speak of. Probably easy to just buy everything at once online. Just don't want to buy wrong ones. Thanks for the help.
Old Aug 11, 2014 | 10:16 PM
Critter's Avatar
Check the one at the top of your picture, the one to the right and the tensioner pulley. Remove the belt first then spin using your finger.
Not familiar with your tensioner setup, but do a search to release the tension to remove the belt, you have a picture to help when you replace the belt as far as routing. Any good auto parts store will have a belt for you, do not leave this go as the serpentine runs everything, alternator, water pump, power steering a Benz with no power steering is not a good day
Old Aug 12, 2014 | 01:09 PM
ah526's Avatar
c300
Thank you all for the help. I bought the belt, went to shop, he said I needed one threaded pully. He ordered it and then told me price of $90 for the pully. I looked it up on my phone while waiting and the and the Advanced Auto Parts down the street had it for around $15. I asked if he ordered the correct part because $90 seemed like a lot. He said no. My bill to install just the belt was $70 and it took 20 min plus calls to get new pully. I will pick up the part from the Store for $15 later today and I am hoping this $70 charge includes the pully install but I doubt it. If its not included I will go elsewhere.
Thank you all for your help. I hope this helps others.
