Old 06-29-2015, 03:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior Guides
Print Wikipost
How to remove command head unit (specifically the air vents to access the HU)
Old 06-10-2015, 10:27 PM
benjikc250's Avatar
2012 C250 Sport
Hello,
I am currently in the process of trying to remove my command head unit so that I can plug in a Farka cable (I am installing a back up reverse camera). I am following some very helpful instructions I found elsewhere on mbworld, but I am stuck at accessing the HU. To access the HU, you must first remove the trim/centre console air vents (which are one piece). I was able to unclip the trim with some dashboard tools I purchased, the last step before the whole thing comes off is to undo two clips inside the air vents (one on each side). However, this is proving to be very challenging.... I cannot get the driver side clip to do anything!! The entire thing is stuck because of this last inner vent driver side clip.
FYI - I have a 2012 c250 (w204) - but the key note here is that in 2012 they did a facelift in the dashboard design. (My screen is fixed, does not pop out the top like in previous years of this body style).
Any help would be greatly appreciated!!
Old 06-11-2015, 10:33 AM
chrisdean's Avatar
W205 C200 AMG Line Premium
Just pull a bit harder. When you disconnect the wiring, tape it to something so you don't forget to reconnect. The 2 head unit screws must be undone at least 1cm the you need to tap them back down for the catches to release.
Old 06-11-2015, 11:32 AM
xEryx's Avatar
2014 CLS63 S AMG
I had the same issue and took like 30 minutes of clip pushing and pulling to get it to come out. Sad to say, friend broke one of my air vent thingies. If you are looking at the YouTube video on how to access the back of the HU, it is NO WHERE near as easy as it looks, you have to be pretty rough.
Old 06-11-2015, 02:03 PM
benjikc250's Avatar
2012 C250 Sport
Thanks @chrisdean & @xEryx
Heres a picture of the current state of my dashboard!
Also, a photo of the actual clip on the inner vent (driver side). Lots of mixed info out there... do you A) Push it in towards the driver side, or B) Pull it out towards the passenger side?
I've managed to get the trim off quite easily using some prying tools.
The only clip I can't get off is the inner vent driver side. Do you push it in or pull it out??
Old 06-11-2015, 02:22 PM
chrisdean's Avatar
Never knew those clips were there, I just made sure that I had a firm grip around the vents and pulled until it came away.
Old 06-11-2015, 05:19 PM
SaphGreyC63's Avatar
2012 C63 AMG Sedan
http://cdn.macarbon.com/install_guid...stallation.pdf
Enjoy! Super easy!
Old 06-11-2015, 07:41 PM
benjikc250's Avatar
2012 C250 Sport
Originally Posted by SaphGreyC63
Whoa that's great information. I am still however stuck on the vent clips tho.... it's not as easy as it looks in any of the online videos. This description says: "There are two prongs on each side of the airvent. Using the pick, ease the prong around the edge of the opening in the dash."
What do they mean by 'ease the prong around...." I've been on this for hours and cannot figure it out....
Old 06-12-2015, 07:26 AM
xEryx's Avatar
2014 CLS63 S AMG
When I got mine off we were pulling the clips in the whole time. Right one came off super easy, but left one took over 30mins of pulling in and clip moving. I also saw some guides say that you need to pull out so I am confused. Lets just say I am not excited for taking it off again when I have to fix my broken vent thing.
Old 06-15-2015, 04:11 PM
TheRulesLawyer's Avatar
C350
You need to pull those clips into the vent to release. And you need to pull strongly to get it to release.
Old 06-16-2015, 06:11 AM
xEryx's Avatar
2014 CLS63 S AMG
I took it out again to fix the air vent, super easy this time. Pull the clip and and hold then just start aggressively pulling, I was definitely not afraid of breaking anything this time around.
Quick Reply: How to remove command head unit (specifically the air vents to access the HU)
