Spark Plug Dilemma
Old Oct 26, 2015 | 11:25 AM
JWH321's Avatar
2008 C300 Luxury
Spark Plug Dilemma
Its time for plugs for my 2008 C300 (Luxury spec) automatic.
It is my intent to use NGK plugs.
My owner's manual says NGK PLKR 6A MPP33.
The NGK website recommends NGK 7A Mpp33 (one heat range colder).
Which plug is best?
Old Oct 26, 2015 | 01:47 PM
ickdeep's Avatar
'13 M5 | 08 C300 (Sold)
Which plug is best?
I would call your local part store and see what they recommend. I just replace my spark plugs last weekend but I forgot which exact ones I got.
Pretty easy job.
Old Oct 26, 2015 | 02:15 PM
JWH321's Avatar
2008 C300 Luxury
Well I just heard back from NGK. They tell me that the "6" heat range was superceded by the "7" range in 2011.
NGK PLKR 6A MPP33 is what I have ordered.
Old Oct 27, 2015 | 10:47 PM
JohnnyC300's Avatar
2009 C300 Sport 4Matic
I have an '09 and am considering the change. 60k miles in my car but no known reason to me I should other than the expired time limit. Why did you decide to replace yours?
Old Oct 28, 2015 | 09:27 AM
JWH321's Avatar
2008 C300 Luxury
I'm approaching 100K miles and the plugs have not been replaced. The dealer "inspected" them at 62K miles and said they were good. The good folks at NGK provided me with a tech bulletin from Mercedes that changed the spec from a "6" heat range to a "7" heat range so I have obtained NGK PLKR 7A MPP33 plugs.
I have since begun doing most of the maintenance tasks myself (following a debacle where the dealer insisted that a transmission refill took only 5 quarts of fluid and sent me home that way -- I drove to another dealer who filled it properly and have never gone back to the original dealer).
The car is still performing properly, and I've had no misfires or any other malady but I took one plug out and found its gap had worn to .042 in. The specs call for .031.
I am going through oil, filters, brake pads, rotors, brake fluid, and tires, and I figured this was just a good time to make it all fresh.
The car is otherwise perfect and continues to provide 30 - 31 mpg on the highway. I've had it on the alignment rack three times in its life, and each time, no changes were made. The current tires have gone 43K miles and are evenly worn.
On my last visit to the dealership I was provided with a new "C300". It is a wonderful replacement, and I would have likely considered it more if the issue with the transmission fluid had not come up. We'll likely replace my wife's car with one at some point in the next year (her C230 has almost 250K on it).
Old Oct 29, 2015 | 12:20 AM
JohnnyC300's Avatar
Thank you for your informative and clear insight
Old Dec 27, 2015 | 01:59 PM
bpeter's Avatar
C220
JWH321,
Can you share with us the tech bulletin from Mercedes that changed the spec from a "6" heat range to a "7" heat range?
Thanks.
Old Dec 27, 2015 | 02:38 PM
michail71's Avatar
2013 C250 Sport
Slightly OT but how do the coils hold up in these cars? Should the be replaced with the plugs?
Coming from VW is was almost a joke how often the coils would fail.
Old Dec 27, 2015 | 04:00 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
I wonder if this has anything to do with the amount of ethanol in gas. IIRC, manufacturers were recommending a colder plug because of that.
Old Dec 27, 2015 | 04:53 PM
bpeter's Avatar
C220
I have had multiple generations of MB vehicles and have never had a spark plug coil fail.
Old Aug 30, 2019 | 01:43 AM
Bobby204's Avatar
2001 R129 SL500, '08-'20 W204 C350
Yeah coil replace only when broken per auto parts guy. It's been a few years and now stores are recommending iridium plugs at temp range 7 which is a little cooler than the 6 originals (NGK LKR7AIX)
Dealer wants $500 now for plugs
Old Aug 30, 2019 | 11:39 AM
JettaRed's Avatar
Veteran: Army
...The dealer "inspected" them at 62K miles and said they were good...
Seriously!? Why would they pull the plugs and not replace them? The reason they charge $500 to replace your plugs is because of the labor involved. 😒
Old Aug 31, 2019 | 08:31 PM
Bobby204's Avatar
so i put those iridium R7 in and car runs bit sluggish, so I reset the ecu and engine perked up.
Anyways, anything the old plugs are telling me? they all had ash deposit of various amounts, I blew them off. 2 threads are drier while 4 are oily. TIA for youe feedback!
Old Sep 3, 2019 | 05:33 PM
Tom in Austin's Avatar
2019 S560, 2015 Honda Civic Hybrid
Boy, those have a lot of threads on them!
