Headlight/Illuminated Star wiring help
Old Apr 12, 2016 | 05:32 PM
motefaint's Avatar
2013 C250
I purchased an aftermarket illuminated LED grill star and have removed the stock star and popped the new one in. Now my problem is figuring out which wire to tap into to power it. I figure I can ground out the second wire anywhere on the body but I can't figure out which hot wire I should splice into. I would like the star to be lit with the day running lights and also at night and preferably even when the doors are locking/unlocking. I haven't seen any guides for installing one of these on a w204. I've attached a picture of the headlight wiring harness on the passenger side. Can anybody help me figure out which wire I need? Thanks in advance.
Attached Thumbnails Headlight/Illuminated Star wiring help-img_3687.jpg
Old Apr 12, 2016 | 05:34 PM
motefaint's Avatar
2013 C250
Also the only instructions that it came with were to connect the red wire to ACC, black wire to the earth. I'm not sure what ACC is or if it will do what I'm hoping for.
Old Apr 12, 2016 | 09:07 PM
motefaint's Avatar
2013 C250
After mining the web for a couple of hours I came to find that the gray/white wire powers the passenger front standing and parking lamp. I used this to splice in the hot wire on the LED star and it works great. Connected the other wire to a grounding nut nearby. Now my LED star illuminates when locking/unlocking and runs with the daytime running lights and also at night with the normal headlights. Hope this helps out someone else. My car is a 2013 C250.
RE:
Originally Posted by romeo291
Also, from the 10 pinout plug on our car, you can see the following:
2009 Plug
1 - (brown wire) - Right wheelhouse ground point
2 - (yellow wire) - Right Low Beam
3 - (white wire) - Right High Beam
4 - (gray/white wire) - Right front standing and parking lamp
5 - (gray/red wire) - Right front standing light 2
6 - (black/green wire) - Right front turn signal lamp
7 - (black/blue wire) - *not sure*
8 - (green/blue wire) - *not sure*
9 - (brown wire) - Right wheelhouse ground point
Old Apr 12, 2016 | 09:11 PM
MB Marko's Avatar
2012 C300 4Matic Sport Sedan
https://mbworld.org/forums/c-class-w...ml#post6084089
check out this thread theres some PDF files you might like to take a look at
heres another thread
https://mbworld.org/forums/c-class-w...ated-star.html
should be all you need
Old Apr 12, 2016 | 10:47 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
Great. Thanks for the follow up post. I appreciate it when posters follow up with the answer
Old Apr 15, 2016 | 09:28 PM
ghlkal's Avatar
Did you get your star off of eb*y?
Old Apr 17, 2016 | 03:20 PM
Demvang's Avatar
2011 C300 4Matic Sport
I got it from Aliexpress for less than 60 bucks. Highly recommended there.
Attached Thumbnails Headlight/Illuminated Star wiring help-20160322_005855.jpg
Old Jan 9, 2018 | 12:55 AM
Chaldean's Avatar
2018 Mercedes GLC300
Which head light wires to solit
I have a 2018 GLC300, I just bought the illuminated star and I want to add it to the headlight. Which wires do I split?
