HOLD brake stopped working
Old Jun 9, 2016 | 10:28 AM
MDMercedesGuy's Avatar
2024 GLS450
This morning on the way to work, I attempted to use the HOLD feature while at a stop light, like I do all of the time. No matter how I pumped the brake, let it roll, release it, nothing - I could not get it to kick on. Restarting the car did not help.
Never had an issue with it in 4 years of every day use. Has anyone seen this happen? I'm wondering if a battery cable pull will fix it, or what the root cause might be.
Old Jun 10, 2016 | 08:55 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Agreed - sounds like you'll definitely need DAS. No other warnings then? Does the car still hold itself for a few seconds if you are on a hill and release the brake? That's the other part of the adaptive brake tech.
Old Jun 13, 2016 | 10:02 AM
2024 GLS450
Ugh, damn. My seatbelt was on - the car never moves without it
I'll have to see if hill start assist is working or not the next time I pull it out of the garage.
Old May 3, 2025 | 08:19 AM
Ligedy's Avatar
W204 C250
hi, my W204’s brake HOLD just started doing exactly the same.
did you find the root cause or a fix?
Cheers
Old May 3, 2025 | 10:12 AM
W205C43PFL's Avatar
Cheers
Might be aux battery.
Old May 3, 2025 | 10:13 AM
W205C43PFL's Avatar
https://mbworld.org/forums/gl-class-...ml#post9154225
Old May 4, 2025 | 10:06 AM
W205C43PFL's Avatar
Did the replacement fixed it?
