Oil change interval, M272 C300
Old Sep 7, 2016 | 08:39 AM
pappasurf's Avatar
w204 c300
Hi guys!
How often do you change oil and filter on your vehicles?
I used to do it every 10.000 km but now, considering my current mileage that would mean I need to change it 3 times a year
Seems to much so I would need your advice on what´s the optimal interval.
Thanks!
Old Sep 7, 2016 | 12:25 PM
chrisridebike8's Avatar
'10 C63
Oil is cheap. Engines are not. I do mine every 5,000 miles even though 10,000 miles is the recommended interval. That means I do 4 changes a year and go through two sets of rear tires and a set of fronts.
Old Sep 7, 2016 | 01:16 PM
Alfadude's Avatar
2012 C300 4Matic
"Optimal" interval? I guess that depends on how you define "optimal". Unless you run your car extremely hard or drive your car consistently in some extreme conditions, I would say go by what is recommended in your owner's manual. The Mercedes engineers came up with that for a good reason. There are always threads on here (or on pretty much every other car forum) about this sort of thing and there is always debate on what is "best". If the manual says 10K miles there are those that figure 5K MUST be better, "just to be sure" or it is "cheap insurance". To each his own, but my feeling is that for every day driving that most of us do the recommendations in the owner's manual are more than sufficient. To me, I go by the book and leave it at that.
Old Sep 7, 2016 | 01:29 PM
'10 C63
The only real way to tell when you need to change your oil is blackstone oil analysis.
Old Sep 7, 2016 | 03:04 PM
stgry1's Avatar
c300 Sport
People are concerned with the changing of the oil when the real issue is the filters. Many oil filters are unable to properly filter particulates after a certain period of absorption. The V1s in the oil however, will be fine for the 10k stretch. I usually pop a new oil filter on every 5k or so depending on my oil change schedule. A filter on these engines is easy to change and gives me peace of mind....but of course to each his own.
Old Sep 7, 2016 | 07:34 PM
Just204's Avatar
Mercedes w204 4matic sport
He's right on this one about the filter being a big limiter. Not all filters are equal and don't get cheap ones. I might do that since I'm coming up on the 5k mark soon.
Old Sep 8, 2016 | 01:09 AM
Josh.A.Hussey's Avatar
2017 C43 AMG, 2010 C350 4Matic, 9 Motorcycles
All information provided above is good. I would like to add also, although not particularly relevant because you seem to drive enough, that if you DON'T drive your car often at all, you should also do regular oil changes earlier than manufacturer recommended.
AKA, if you have a 7 year old car with 16k km's (<10k miles), you should have already changed oil more than once.
Old Sep 8, 2016 | 01:55 AM
pappasurf's Avatar
w204 c300
The thing is a local dealership tells me that once a year oil change is all I need. But I know enough that it's the mileage that counts, not weeks, months or years. So I changed it every 6200 miles (10000 km-s). Considering I drive 90% in heavy traffic where engine revs no more than 2500 rpm with occasionsl blasts on highway when I really floor it to over 250 km/h just to "clean" it up a bit it shoul be enough.
Old Sep 8, 2016 | 08:04 PM
stratman1954's Avatar
2012 C300 sport
1 year or 10k, whichever comes first
Old Sep 9, 2016 | 03:25 AM
c300white's Avatar
2008 C300
Yep - show me someone that had oil related engine issue with 1yr 10k changes ...most of the forum posts about sludging or other oil related issues are where people ran the oil way beyond the service interval. There are a few exceptions however - like Hyundai gdi engines ...
Old Sep 9, 2016 | 04:10 AM
pappasurf's Avatar
w204 c300
OK, if I keep my intervals within 10.000 km I should be fine?
Old Sep 9, 2016 | 04:56 AM
C3004Matt's Avatar
2012 C300
You should be. I would get it around 7,000-8,000 just to be on safe side though.
Old Nov 14, 2016 | 08:21 PM
Denis2015's Avatar
C300 4matic 2015
Reading the maintenance booklet for the MB C300 2015 they refer to engine number model. Where can i find it?
Only reference i found is Engine type 2.0L L4 DOHC 16V AWD
I even lookup the VIN number but can not find any reference to the engine number model.
Anybody know?
The reason i need to find out is about oil change, in the booklet it is either 15000 or 20000km (depending on engine model number)
/1 year.
Old Nov 15, 2016 | 06:35 AM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
Personally I do mine every 10,000km, but change the filter every 5k.
Old Nov 15, 2016 | 11:46 AM
Moto_Guzzi's Avatar
2008 C350-Sport-AMG-Active Agility Pack(Not reliable) +Izuzu KB6 3L(It seems Reliable)+Mazda
Oil change
Every 5000Km...+/- Mercedes 229.5 Oil + Filter.
Old Nov 15, 2016 | 12:19 PM
Demvang's Avatar
2011 C300 4Matic Sport
Every 8000 miles here. I'm at 54xxx miles and will have the oil changed @ 56k.
Old Nov 15, 2016 | 07:04 PM
pfarah77's Avatar
2008 SL550
The book says 10k mile intervals, all the techs I've spoken with (both dealership & independent) strongly recommend oil/filter changes at 5k. It may cost a bit more but my cars thank me.
Old Nov 16, 2016 | 01:30 PM
Moto_Guzzi's Avatar
Interesting, about 3 years ago I met a mining engineer, and we started talking about oil.
He said to me they did the experiments and the best oil starts to change at 7 000km, this is their max.
I acually did a lifelong experiment on the Mazda engine, got oil cheap(Not rubbish oil) and replaced it every 2500Km. I found that after 50 000Km the valves stabalised and I never had to adjust the tappets after that like before. I later used better oil and changed to 5 000Km intervals.All I do is check them, had a very few times adjust gap smaller, count on one hand. It now has near 300 000Km and engine is clean inside, no oil usage and running strong.
I buy car cash, then drive it till it unrepairable, but you have to look at the fluids. If you replce every 3-5 years you probably never has to do anything from new, next owners problems.
Old Nov 17, 2016 | 10:23 AM
Chastity's Avatar
C300
For United States drivers not on the metric system, that's every 4350 miles (7000km).
Thanks, good info.
Old Nov 17, 2016 | 12:34 PM
Just204's Avatar
Thanks, good info.
The thing is he's most likely talking about conventional oil, synthetic is very different.
Old Nov 18, 2016 | 08:04 AM
ezzcoke's Avatar
C300
I have a 2013 C300 as my daily car and I put in 100 hwy miles on it everyday. Should I change oil every 5k or follow the book, 10K?
Tks..
Old Nov 18, 2016 | 09:15 AM
Alfadude's Avatar
2012 C300 4Matic
Tks..
Go by the book.
