Tips for Manual Driving
Old Oct 2, 2016 | 07:00 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
LMK cause sometimes I like to drive it in manual.
Seems like 7th gear is unaccessable? When I'm on highway I can't shift to 7th manually; actually cant at all. Only goes up to 6th. I figured I might as well try to upshift and save some gas, but it seems like I can't do that much with my route anyway. I get 28MPG on good days though.
When I stop I guess I have to shift it down slowly until I get to the stop? Its not like manual obv.
Idk any tips and tricks
Old Oct 2, 2016 | 11:54 PM
ghlkal's Avatar
2012 E550 v8-Biturbo
On my 2011, "manual mode" sets the upper limit for gearing. It doesn't force the tranny into the selected gear.
Setting the tranny to [3] doesn't keep it in 3rd gear. In other words, if you're in [3], the tranny will still start in 1, and then go to 2, and then to 3. {I haven't tried pushing it to see if the computer will upshift beyond the selected gear when the revs get up there}
The reason you don't see [7] is because [D] selects the entire range.
Old Oct 3, 2016 | 04:19 PM
Adi-Benz's Avatar
Oh.
That's kind of weak then
Slight letdown.
When you switch to manual it downshifts; I was driving ~45mph, downshifted to 4 then reshifted to 5, and then shifted up to 6. And it worked, because rpm's went down, so thats not the same thing then...idk
Old Oct 3, 2016 | 05:03 PM
Alfadude's Avatar
2012 C300 4Matic
You don't "switch" it to manual, you just tap it left to downshift, right to up shift. Generally if you are going to use it you are probably looking to downshift for more performance. Then it will hold the revs in that gear. When you stop it will still show the gear you had it set to, but it will start in 1st in Sport, 2nd in Economy. Then it will keep up shifting on its own until it reaches the gear you had selected before. Hardly a manual, but you can have a little fun with it. Still miss not driving a manual car anymore.
I have noticed is the usual acceleration lag that everyone complains about. However, I have found out that when I have my whole foot flat against the accelerator pedal and accelerate with my foot in that position it seems like the lag smooths out and comes on quicker. I am guessing that is because I typically only use part of my foot on the pedal. I kind of have my heel between the accelerator and the brake, so that it is easier and quicker to brake as I can pivot on my heel. By doing that I only am pushing down on the accelerator with the top part of my foot and I guess that feels like I have to put more force on the pedal to get it to do its thing. When my foot is flush against it it feels like less effort to push the pedal and I get the sensation that it responds quicker. Am guessing that might be what the sprint booster must feel like. Maybe its just me, but I would guess a lot of people work the gas and brake like I do and maybe the pedal is designed more for the full foot on it. Then again, maybe I'm crazy.
Old Oct 3, 2016 | 06:22 PM
Adi-Benz's Avatar
Naw Alfa, I do a similar thing, and sometimes I don't pick up speed as quickly as "others" would like to. So they pass me in their prius :O
Right well that clears it up. I guess its a good thing in a way to you cant screw up your tranny, but still kind of lacks the experience.
Someone said to get rid of the lag they set their car to D6 and the lag just went away. Doesn't make sense but maybe someone should try it and report back; I've sort of gotten used to the lag since I've been driving only this a lot recently, so I won't be able to tell much I don't think, but I'll give it a shot.
Old Oct 4, 2016 | 09:15 AM
Alfadude's Avatar
2012 C300 4Matic
I have done that, where I put it in D6 and that "seems" to help a little, especially on the freeway. Even better is leaving it in a lower gear, like D5 or D4, like on city streets, if you know on the streets you will be driving on will not have it rev higher than you would like.
I also like to just quickly, lightly tap the accelerator and it will quickly drop a gear, kind of like heel and toeing in a manual. If you time it right the acceleration is a lot quicker because you are already in a lower gear.
It will never be as good as we would like, but I have kind of come to terms with it after driving the better part of the last 30 years driving nothing but manuals.
Old Oct 4, 2016 | 06:57 PM
Adi-Benz's Avatar
Yeah
Also on a side note, I left my car outside last night and this morning driving it on my daily commute, it seemed like a whole different car...literally, it was picking up speed like a c63 and I was barely hitting it...it was like I got a tune and sprintbooster all at once lol. No idea, but on the way back it was back to normal. Hm.
Old Oct 10, 2016 | 09:45 PM
jlr82's Avatar
2018 C300
About the car not wanting to shift into 7th on the highway... If you have it in Sport mode it will take a while to shift to 7th and usually won't do so on mine until I hit 70+ MPH. If I switch it from Sport to Eco mode while I'm on the highway it will instantly upshift to 7 on its own.
Old Oct 11, 2016 | 12:05 AM
edgalang's Avatar
Factory ordered 2012 MB C350 w/Dynamic Handling Package
"Manual" mode is not common, and you generally get it as part of the "dynamic handling package".
The picture above shows both the "sport mode" and the "manual mode" buttons. The "manual mode" button acts exactly how you described in your original post and will hold gears to your hearts content. However without true "manual mode" shifting through gears is really a range limiter and doesn't represent the gear your in.
Old Oct 12, 2016 | 06:06 PM
08c30's Avatar
W204
Just started messing around with this as well since I miss standard. Exhaust and engine sounds so much better/consistent on manual vehicles IMO.
I've been somewhat nervous that usage will put extra wear on my transmission though...
Old Oct 13, 2016 | 07:32 PM
Adi-Benz's Avatar
It shouldnt, can put wear on engine though if you drive at 7000rpm lol,
Old Oct 14, 2016 | 02:31 AM
C3004Matt's Avatar
2012 C300
Thats not manual. Its fake shifting on an automatic transmissions. If basically shifts for you
Old Oct 14, 2016 | 08:19 AM
ezshift5's Avatar
Mercedes C250 Coupe
I owe you one (all this time I was under the impression the car should be at a standstill when pressing down the switch for the eco - sport change).
I really don't drive this beauty very much (but it's a striking little coupe).
ez
Old Oct 14, 2016 | 02:26 PM
Adi-Benz's Avatar
Ok, guys, we already established its not a true manual. I already knew that, phrased incorrectly, but it was regarding the function of the system.
Also MB recommends doing it at a standstill, but when you realize it halfway into your drive, who's gonna stop? xD
Old Oct 17, 2016 | 02:01 PM
edgalang's Avatar
Originally Posted by Adi-Benz
Also MB recommends doing it at a standstill...
Link? This is the first time I have ever heard of this and I disagree. Maybe you are confusing this with 4WD transfer cases on other cars/SUVs.
Old Oct 17, 2016 | 02:30 PM
Adi-Benz's Avatar
I never said I do it and a standstill...haha.
Some other forum member posted it from MB on a different thread. I don't remember, and I definitely wont be able to find it.
All you can do is accept or refuse my word, I don't mind. As said, I don't bother with it either way :S
Old Oct 17, 2016 | 02:59 PM
edgalang's Avatar
I'd definitely shrug it off as internet rumor. The only time you require to be on standstill (or extremely low speed) is when you are shifting to reverse, or when switching between Hi/Low on manual transfer cases. The rest can be done on the fly.
Old Oct 24, 2016 | 11:48 PM
jlr82's Avatar
2018 C300
The manual (page 156 in the USA manual) specifically states:
"Only change from automatic drive program
E or S to manual drive program M when the
vehicle is stationary."
The W203 manual used to say the same thing about changing between C/S modes.
That said, even in my W203 the tech guys always said you can change it whenever you want.
https://www.mbusa.com/vcm/MB/Digital...14_C_Sedan.pdf
Old Oct 25, 2016 | 08:02 AM
dlgkswh88's Avatar
2014 C300 4MATIC
Just wondering if some people would interpret the wording differently.
When I first read the quoted wording from the manual where it says "E or S to Manual" my interpretation was:
'E to Manual' or 'S to Manual' vs. 'E to S'?
Which means E to S can be done without vehicle being stationary?
Honestly, my W204 C300 did not come with the M mode, hence I always play with E/S mode while driving and experienced no problems.
Maybe the car equipped with the M mode should follow the guideline in the manual. (Change E/S to M when stationary)
Just my thought.
Old Oct 25, 2016 | 10:20 AM
jlr82's Avatar
2018 C300
You're right, it is technically stating about switching from either of the automatic programs (E/S) to Manual. In the older W203 manual the wording was different and said the same thing about switching between C/S only when the vehicle was stationary. The W203 manual states the following:
"Never change the program mode when the gear selector is out of the position P."
I switch between E/S all the time while driving and I've never experienced a problem or any odd behavior due to it.
