What size are my front rotors? 322mm or 295mm?
Old Oct 13, 2016 | 10:40 AM
Colin G's Avatar
2008 C-230 4Matic Sport
Car is a 2008 C230 4 Matic 2.5L V6 with the sport package with option code 952.
I need to order rotors and am unsure what size the fronts are. 322mm or 295mm?
I am getting conflicting info on the rotor size with that option code so any assistance would be appreciated. I need to order rotors and am looking at Bosch Quiet cast over OEM.
I am also having a hard time finding rear cross drilled rotors like the stock ones that came on the car. I am assuming my rears are 300mm.
Old Oct 13, 2016 | 11:22 AM
Colin G's Avatar
Originally Posted by Plutoe
You don't order rotors by size---you order by the correct part number---what's your VIN!!
I am not buying OEM rotors as they rust and I want something coated like Bosch ect. Most I see on various sites are listed by size and not by Mercedes part #.
VIN is WDDGF85X18F147654
Old Oct 13, 2016 | 12:44 PM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
If it's a C230 they're probably 295mm
If you still have the OE drilled rotors, the rotors will have 3 holes in a row if they're 295. If they're 322, they'll have 4
Old Oct 13, 2016 | 12:53 PM
Colin G's Avatar
Thanks Funk. I assumed they'd be the smaller ones.
I'd still like to find rear drilled but probably won't be able to unless I go OEM or some esoteric after market brand.
Old Oct 13, 2016 | 01:59 PM
Colin G's Avatar
Thanks Plutoe.
I am looking at Bosch rotors or Brembo. Not sure on pads yet. OEM brake dust is nasty.
Old Oct 13, 2016 | 02:06 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Drilled rotors are basically for looks at this point. Also they are more prone to cracking.
Old Oct 13, 2016 | 03:42 PM
Colin G's Avatar
To be honest it does not really matter to me if the rotors are drilled or not. That is what came stock so that is simply what I was looking for but with a coating to minimize rust. I just hate looking at a rusty rotor through the wheel spoke spaces.
Old Dec 29, 2016 | 10:14 AM
Colin G's Avatar
My fronts are 295mm (3 holes) so would that make the rear rotors 300mm?
