Need Expertise on Rotor Wear | 2009 C350
Old Nov 11, 2016 | 08:21 PM
Nicholi2007's Avatar
2015 C400 Tenorite Gray
I know most mechanics try to sell you on pads and rotors.
My understanding is that you replace the rotors once they get grooves in them.
My rotors have grooves in them but did not look too bad. *See photo.
The car has 85,000 miles. I bought certified pre-owned at 48k.
Q. What is the rule of thumb here?
Rotor wear C350 2009
Old Nov 11, 2016 | 11:03 PM
dennish's Avatar
1992 MB 190E, 2016 MB C300
I don't change rotors with light superficial grooves if there is no pulsing noticed at the brake pedal and they measure within tolerances .
Old Nov 12, 2016 | 12:56 AM
Rocman8's Avatar
E55
The minimum thickness spec is stamped right on the hub part of the rotor. Measure it.
Old Nov 12, 2016 | 01:30 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
[QUOTE=Nicholi2007;6967137]I know most mechanics try to sell you on pads and rotors.
FYI :My disc original thicknesses & wear limits. :-
Front - Ventilated :-
Original = 28 mm
Minimum before repair = 26.5mm
Minimum limit = 26mm
Max runout = 0.12mm
Rear- Solid.
Original = 10 mm.
Minimum before repair =8.8mm
Minimum limit =8.3mm
Maximum disc runout =0.15mm.
I found it difficult to measure accurately without a micrometer.
Ask the mechanic for the figures then you can make the decisions on when they can be replaced.
Old Nov 12, 2016 | 11:32 AM
c300white's Avatar
2008 C300
Micrometer is cheap at harbor freight ... Yep a little bit of grooving might be ok - but also check the "lip" on the edge of the rotor - and any cracking around the cross-drill vent holes -some autoparts stores will "turn" rotors for you - which might be a lot cheaper than getting new ones if they still meet thickness spec and otherwise look ok ...
Old Nov 13, 2016 | 06:37 AM
psaldanha's Avatar
Mercedes C220 AMG Style
Well, is very easy to check if rotors need replacement.
I too will change my front rotors this days (its a w204 c220 cdi with ventilated discs at front).
In the life of the rotors, i have surfaced them once (theu had some grooves, ask to surface, cost me 5 € both).
But the rotors have a physical limit on them. Just search on the edge of the rotor a lip on it. Thats your limit!
Dont forget to check right, because the the rotor surface could more inner than the limit lip!!
By the way, i will buy ceramic pads for front!
Old Nov 15, 2016 | 01:47 AM
Carsy's Avatar
Nicholi2007,
Any luck?,
Old Nov 15, 2016 | 10:09 AM
Originally Posted by Carsy
Nicholi2007,
Any luck?,
I ended up replacing the pads before I posted this as braking was extremely bad. I was concerned the brakes would go any minute
I was hoping someone could look at by sight and tell. Wishful thinking.
I bought rotors so maybe next time.
Braking still feels a bit soft. Perhaps a break in period....
