how to play music through bluetooth
Thanks,
james
and then connected my phone to the benz and then to the bluetooth. Then chose aux as the play option in the car, and then boom. Easy Not sure if 2009 is dff
I have cables in my glove box that I attached an iPod adapter to. See pic below.
I connect it to my iPhone and it plays all my iTunes tracks. Once I get a new iphone, my current iphone will be left in the glove box. You can also buy a used iPod on ebay, load it up with music, podcasts, etc. and keep it plugged in permanently.
the nav screen can read all the playlists and tracks, so you can navigate through your music with the onboard screen and console knob.
What is the best way to get this to work and look decent, and provide continual power so that it just works without ugly cables?
K
K
It is a bluetooth adapter you plug into the 30 pin iPod cable in the glove compartment. Your phone will then make 2 bluetooth connections to your car, one to MB Bluetooth for the telephone and the other to BOVEE1000 for music, podcasts, car navigation, etc.
The car will pause streaming music when a call comes in. The steering wheel controls work as well.
You can press the "End Call" button on the steering wheel when the small dash board display is on "audio" to get to the playlists on your device. then you can use your "arrow" and "ok" and "back" steering wheel buttons to select songs and playlists.
2008 C300 4Matic Sport without command
iPhone 6s
https://www.amazon.com/Bovee-1000-Bl...A3BVA1L98F0PER
iPhone 6s
Can you explain the phone connection in detail? I have an 08 S550 and brought the Bovee. I can play music but can't stay connected to it when I make or receive calls. I have the phone connected to command but I didn't have the original puck and I don't see the car in my Bluetooth list.
