Squeaking belt help
Old Mar 2, 2017 | 10:29 AM
CGC's Avatar
CGC
2009 C350
Squeaking belt help
So i have a squeak coming from my belt. I think it might be the tensioner, but i'm not sure. Anyone have an idea on what squeaks first generally on the W204? I know this is a random question and could be any of the idlers, just hoping for more ideas. I used my stethiscope and was not able to determine which one was the culprit.
Old Mar 2, 2017 | 03:15 PM
CGC's Avatar
CGC
2009 C350
Originally Posted by Plutoe
I would say that if you did the stethoscope then it's not the tensioner or idler---keep looking and have you noticed any belt ware!!
With the stethoscope it was loudest at the tensioner, it just wasn't a high pitch sound like I was hearing. Of course the sound tends to go away when it warms up. No belt ware.
Old Mar 2, 2017 | 05:25 PM
StrelingA's Avatar
08 C350
its not the tensioner its the idler pulley at the top of the motor a little the left. had this same problem... ecs tucnning has the kit with belt
Old Mar 2, 2017 | 07:03 PM
CGC's Avatar
CGC
2009 C350
Perfect! Do you happen to know the part number? I looked on their site and didn't see any that came with the belt.
Old Mar 4, 2017 | 06:45 PM
StrelingA's Avatar
08 C350
https://www.ecstuning.com/b-genuine-...2722000270kt1/
https://www.ecstuning.com/b-genuine-...2722000270kt2/
Old Mar 7, 2017 | 10:17 PM
pezzy669's Avatar
'11 E350 4Matic Sport
Would you recommend the full rebuild/replace of the idler and tensioner pulleys once the belt wears out? My original belt on my '09 is making a little bit of noise when cold @ 70k miles and I am sure it is nearing end of life due to dry rot. Just curious if I don't have pulley noise yet if I should just replace them when I do the belt.
Thanks in advance!
Old Mar 7, 2017 | 10:35 PM
StrelingA's Avatar
08 C350
Thanks in advance!
Yes when u change your belt do it because it will go bad sooner or later ..IMO just to have a piece of mind..
Old Mar 26, 2017 | 07:04 PM
CGC's Avatar
CGC
2009 C350
I picked up the belt kit. I was surprised to find I didn't have E-torx bits considering I have a Snap on box full of tools. Does anyone know the size you need for the tensioner bolts?
Old Mar 26, 2017 | 07:13 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
I just did my tensioner, I had noise from belt (literally just replaced it 10 minutes ago). Sound is gone and its smooth. $30 win. I believe the torx screws are E13. Check "pelicanparts c300 diy" and there should be a diy with all the info.
Old Mar 26, 2017 | 08:44 PM
CGC's Avatar
CGC
2009 C350
Thank you!
