W204 C class A pillar trim
Old Apr 20, 2017 | 10:32 PM
superangrypenguin's Avatar
A car
How do you remove the trim on the interior side of the A pillar?
I want to run a wire from the dash to the top of the windshield in the center.
It'd be easier if I can remove the driver's side A pillar interior trim which has the airbag. How do I pop that off?
Thanks!
Old Apr 23, 2017 | 01:01 PM
dieseldoc's Avatar
2022 E350 Diamond White Metallic, 2016 GLC300 Dakota Brown Metallic
Remove plastic airbag label. Once off . Metal tab inside. Push-up. Then take hold of trim and pull up from dash and out towards you.
Old Apr 23, 2017 | 01:14 PM
arkim989's Avatar
C320 sport 2003, c300 4matic sport 2013, 2018 GLE63 AMG
I have dash cam on the center up front window to the cigaret lighter outlet, you can just stick the wire between the trim and window and just work through under the glovebox without removing anything trim.. holds fine and i dont see the wire.
Old Apr 23, 2017 | 01:25 PM
A car
Do you have a pic?
I'm struggling to understand what you're saying here!
Thank you. Should I disconnect the batt first?
Old Apr 23, 2017 | 02:11 PM
dieseldoc's Avatar
I would disconnect battery so that you do not have issue with airbag.
Old Apr 23, 2017 | 05:45 PM
arkim989's Avatar
Sorry for my english, i pulled the wire out for you to see what i mean exactly, but i used credit card to push the wire in between glass and trim.
Old Apr 23, 2017 | 05:53 PM
ItalianJoe1's Avatar
2003 CL 600
There's no messing with the airbag when you remove the pillar trim, it's just a cover over the airbag. Just remove as mentioned above, no need to disconnect the battery.
Old Apr 23, 2017 | 06:13 PM
A car
Ah yes, perfect. Thank you everyone.
I realized that the cap just pops off. I've been such an effing idiot. I thought it was this thing that if I poked it it would explode :O
All this time I was so worried, lol. Thanks again
