Just wondered when you top suckers inspect your underside
i.e. Power rack & pinion seal & steering boots,
steering joints for wear,
engine oil & coolant leaks ,
radiator for insect build up & leaks,
exhaust system for damage,
underside guard stone damage
not to mention brake calipers for early sign piston seal leaks ,
transmision rear seal leak ?
condition of engine mounts ,any evidence of leak,
how are your tail shaft universals & driverubbers?.
While your under there how about checking your
diff for seal leaks,
drive shaft boots for damage &
rear brakes lines for stone damage.
Recently saw massive rust damage to sub frame on this site.The owner had no idea until it broke & caused this rear wheels to go wobbly.
All can be done in an extra 10 minutes whilst opening that little drain plug at the bottom of the sump.
Neaderthals? no just people who don't have their head in the sand & don't mind lying on there back for a few minutes hah hah.
https://mbworld.org/forums/c-class-w...ct-levels.html
