DIY Paddle shift install W204 Facelift
I recently installed paddle shifters on my 2013 C350 Coupe 4 matic. I never seen a DIY for that so I thought I would do one myself.
It was a hard and long install but I'm happy I did it!
I bought the paddles on ebay for $200CAD.
So, you need these tools to remove the steering wheel:
- Torx key to remove the airbag
- 10mm hex impact bit socket
- A set of torx key to remove the steering wheel ground
- A pair of plyers to remove the airbag connector and the steering wheel connector
And these tool to for the paddles install:
- A drill to make the hole for the paddles bolts and for the wires
- A dremel to make the holes to insert the paddle into
- A set of torx key to remove the silver trim on the steering wheel
- 2 bolts (under 20mm long)
I won't do a detailed DIY to remove the steering wheel since there's plenty of them online and on youtube. Basically, disconnect the battery and wait 30 minutes to ensure that there's no power left in the car.
Then, unlatch the airbag by pushing in the two openings on each side of the wheel. With the airbag detached, remove the connector with a pair of plyers and do the same for the steering wheel plug. Unscrew the steering ground with a torx key and then attack the big bolt with the impact hex socket. I was able to unscrew it without too much force with a ratchet but I had my impact ready.
With the steering wheel removed from the car, remove the silver trim by unscrewing 4 torx screw. 2 in the back of the steering wheel and 2 in the front behind the steering controls. (the black screws on the pic holding the silver part to the wheel)
Then disconnect the 2 connectors behind the steering controls.
With the silver trim remove, you gotta make 2 holes on each side of the wheel for both paddles. One to run the wire and the other to screw the paddle to the wheel. You got to make the hole where there's a round bump, right in the middle. The paddle is gonna be attached there. Next to it, make another hole for the wire.
Now to the hard part. Insert the paddle into the hole you made and mark around it to know where to cut with the dremel. I simply used a pen. And then, cut carefully inside the line with the dremel. Then, you gotta dig in the material with a dremel sand tool. You gotta do this process until you hit the steel.
Sand tool attachment I used:
The final result should look like this:
Then insert the paddle into the hole and screw it on. I messed up badly this part. The bolts I purchased were too long and I ended up breaking the downshift paddle green board inside it… so be careful about that. I ended up cutting the bolts with my dremel. I had to buy a new paddle at the dealer with the part number two days later and then remove the airbag and change the paddle again. (a $140CAD mistake)
So back to the install, with the paddle wire through the hole and the paddle bolted to the wheel run the wire with the other wires in the little clips.
At this steps, the connectors on the paddles I purchased were not fitting in my wheel. I had to cut the clip and some part on the connector to make it fit. It’s still really solid as the pins are long and I had trouble removing them after for my downshift paddle reinstall, so no worries for that.
Plug the paddles, reinstall the trim and reconnect the steering wheels modules. Screw the trim on the wheel and then reinstall the wheel and the airbag!
The result looks OEM to me. Here’s some pic.
It’s my first DIY, hope it helps some people!
But I'm a bit confused. Which trim / option combination where you don't have the steering wheel paddle shifters? I have a 2013 C350 4matic coupe, and it came with the steering paddles.
OP, it looks like you did the newer style paddles too. Those are the ones usually found on the W205. I have a nice set of big aluminum replacement levers but they only fit those switches.
I still have my old wheel from when I swapped out for shifters. Perhaps I could do this mod and try for the newer paddles so I can finally use my levers.
Now that you have these it will be easier to drive in D6+Sport mode. It actually makes the car driveable. Another nice one is a short hold on the downshift. It will give you max power without the car having to think about it for an eternity. No manual mode though unless coded.
Thanks for the tips and yeah I will have it coded after my extended warranty expires in 1 year!
I couldn't find any good listings on ebay for switches. But anything with some slight modifications should work.
Indeed, there is no aftermarket options for these cars .. even worse for mine (C350 Coupe 4matic). I'm also located in Canada.
Can you please shed some more light on that? Thanks.
I just want to know what will happen if I don't do the dremel part.
