2013 C Class intelligent lights
C220 CDI Sport Plus
I have a 2013 C220 Sport + with the itelligent light system. Im new to the car but when driving at night I constantly get flashed or have people turning om their rear fog lamps thinking I have my main beam on when i havent. I must admit the drivers side lamp does seem to shine right in the cabin of the car in front. The top of the beam seems to be level with the rear view mirror of the car ahead. Anyone else had this problem?
ILS is kind of rare on the C-Class so there isn't usually much posted on here except people upset that they find a car with it or retrofit it without spending many thousands.
It sounds like it could be misaligned or stuck. The drivers side should cut off lower than the passenger side. Both about around the level of the trunk of the car in front of you.
Also, W204 ILS package comes standard with headlamp washer determined by the cutout on each side of the front bumper (see pic). If there isn't, you have aftermarket Depo Headlights. There's a handful of threads about W204 Depo Headlights in this forum which might help you address your issue.
Else, wait till it's dark and toggle between low and high beam. Observe if the beam cutoff pattern go up and down. If all is good, reference the below headlight alignment. Good Luck!
I have 2013 C250 with ILS bought new in late 2012 and I have yet to get flashed by the incoming traffic at night. Are you sure you have the OEM ILS and not depo with faulty or stuck high beam mechanism? Anytime I start the engine inside the garage, the headlight performs the auto alignment, up, down, out and in. Does your headlight do the same when it's dark?
https://www.youtube.com/watch?v=03fHzDEHVV4
https://www.youtube.com/watch?v=NNAfM4ymMsU
However, I know I have the genuine ILS.
Maybe the washer was an option?
Have someone align your headlights in a proper way.
Confirmed the car came with lighting package without washer lamp.
I guess starting 2014, MB removed/excluded the headlamp wash function from the Bi-Xenon Package.
https://mbworld.org/forums/glk-class...p-washers.html
In my previous reply to your reply, I have mentioned I have the 2014 MY, and was curious to find out why washers are not there, but your reply suggested that I don't have the genuine ILS.
Well, I wanted to correct the fact that lighting package on 2014 MY came without the washer.
And yes, OP's car is 2013.
Just post the car's VIN and I'll decode it and post all the options it has ils, washer, etc..
^ this...
hmmm....apology if my previous post had caused some confusions, just thought I could help the OP.
@dlgkswh88 I agree with "alecmascot" and "xsever". Decoding your VIN tells it all and might help others to understand what and whatnot!
Here's mine, post 189 --> https://mbworld.org/forums/c-class-w...or-code-8.html
Engine number ... 271860 30 547101 Front axle 1 ....
Sales des. ...... C 250 CGI Radio unit no. .. PA1138C0432611
Order number .... 0 3 704 59757 Rear axle 1 .....
Production order Rear axle 2 .....
Transmission .... 722997 07 348406 Cab .............
Vehicle title no. Platform ........
Power take-off .. VIN ............. WDDGF4HB1DA760003
Front tire 1 .... Trailer hitch ...
Front tire 2 .... Steering ........
Rear tire 1 ..... Equipment ....... 121A
Rear tire 2 ..... Paint/code 1 .... 149U
Order number 1 .. Paint/code 2 ....
Rims ............ Paint/code 3 ....
Lamps ........... Paint/code 4 ....
Windshield wipers Paint/code 5 ....
Order number 2 .. Door lock .......
Speed. corr. .... Steering lock ...
Transmission lock
Tank lock .......
Delivery date ...
SA code:
03A OIL OFFSET AMOUNT +300 ML OIL
07P STEUERCODE FUER WERKSZUORDNUNG
100A IMITATION LEATHER
121A IMITATION LEATHER - BLACK/ANTHRACITE
149U POLAR WHITE
1U2 SNOW GRID
212B OP. INSTRUCT. AND MAINT. BOOKLET-ENGL. FOR USA/CAN
221 LEFT FRONT SEAT, ELECTRICALLY ADJUSTABLE
222 RIGHT FRONT SEAT, ELECTRICALLY ADJUSTABLE
232 GARAGE DOOR OPENER WITH 284 - 390 MHZ FREQUENCY
240 LED DAYTIME RUNNING LIGHTS
245 TRIP COMPUTER / COMPASS
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
264 LICENSE PLATE ATTACHMENT AMERICA
265 LINES-NO.PLATE DISCONTINUED
280 LEATHER STEERING WHEEL AND LEATHER GEAR SHIFT KNOB
284B AIRBAG LABEL - ENGLISH FOR USA
291 PELVIS AIRBAG (PELVISBAG)
294 KNEE AIRBAG
301 ASHTRAY PACKAGE
309 CUP HOLDER
312B HEAD UNIT LANGUAGE - AMERICAN ENGLISH
342B INSTRUMENT CLUSTER/HU LANGUAGE - AMERICAN
345 RAIN SENSOR
348 EMERGENCY CALL/SUPPORT SYSTEM
414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION
427 AUTOMATIC TRANSMISSION 7-SPEED
440 TEMPOMAT (CRUISE CONTROL)
442 MULTIFUNCTION STEERING WHEEL (12 BUTTONS)
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
475 TIRE PRESSURE MONITOR (TPM) HIGH LINE/MID LINE
486 SPORTS SUSPENSION
494 U.S. VERSION
4U4 RADIATOR GRILLE WITH CENTER STAR
508 NAVIBOX PREINSTALLATION
51U BLACK FABRIC ROOF INTERIOR TRIM
523 RADIO AUDIO 20
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
580 AIR CONDITIONER
584 ELECTRIC WINDOW REGULATOR
59V SPEED- + LOADINDEX 92H XL+94H XL
600 HEADLAMPS - CLEANING EQUIPMENT
608 AUTOMATIC HIGH BEAM SWITCH (IHC)
615 BI-XENON HEADLICHT W.ACTVIE CURVELIGHT RIGHT-DRIVE
634 DELETION - FIRST AID KIT
636 DELETION - WARNING TRIANGLE
668 PRODUCT PROT.F.TRANSPORT VEH. W/ TIE-DOWN HOOKS
690 EMERGENCY SPARE TIRE (MINI SPARE)
705L UNITED STATES (USA)
739 TRIM PIECES - ALUMINUM
763 RADIO REMOTE CONTROL W/ PANIC SWITCH (315 MHZ)
772 AMG STYLING PACKAGE-FRONT SPOILER, SIDE SKIRT
786 AMG DOUBLE-SPOKE WHEELS 18" WITH MIXED TIRES
7XXL NORTH AND SOUTH AMERICA
803 YOM 12/1
875 HEATED SCREEN WASH SYSTEM
887 SEPARATE TRUNK LID LOCKING
889 KEYLESS - GO
909 ALTERNATOR MANAGEMENT
910 DYNAMO WITH HIGHER CAPACITY (FFO)
916 FUEL TANK WITH INCREASED CONTENT
919 AIRCON COOLING POWER PACKAGE
952 SPORTS PACKAGE
954 EQUIPMENT PACKAGE FOR AVANTGARDE VEHICLES
986 DEVIATING VIN WITH MODEL YEAR
989 IDENTIFICATION LABEL UNDER WINDSHIELD
99N STEUERCODE WERK SINDELFINGEN/GRAZ
A22 NEW CONVERTER GENERATION
A43 JOINT FLANGE VARIANT
A63 FE TORQUE CONVERTER HOUSING-0
A87 U VALVE Body ............H VGS 3
A89 REDUCED-FRICTION
B09 REFRIGERANT COMPRESSOR WITH MAGNETIC COUPLING
B12 WHEEL REPLACEMENT TOOL
F204 MODEL SERIES 204
FW LIMOUSINE
G997 TRANSMISSION CODE VERSION 97
GA AUTOMATIC TRANSMISSION
HA REAR AXLE
K15 STEUERCODE FUER SERVICEINTERVALL 15000 KM
L LEFT-HAND STEERING
M010 EVO/VEHICLE UPGRADE ENGINES
M18 DISPLACEMENT 1.8 LITER
M271 R4-GASOLINE ENGINE M271
P47 AUTOMATIC PACKAGE
R02 ALL SEASON TYRES
U10 FRONT PASSENGER SEAT WITH WEIGHT SENSING
U12 FLOOR MATS - VELOUR
VL FRONT AXLE HALF, LEFT
VR FRONT AXLE HALF, RIGHT
XLE HALF, RIGHT
Transmission lock
Tank lock .......
Delivery date ...
SA code:
149U POLAR WHITE
1U2 SNOW GRID
294 KNEE AIRBAG
301 ASHTRAY PACKAGE
309 CUP HOLDER
345 RAIN SENSOR
494 U.S. VERSION
523 RADIO AUDIO 20
580 AIR CONDITIONER
803 YOM 12/1
889 KEYLESS - GO
952 SPORTS PACKAGE
FW LIMOUSINE
HA REAR AXLE
XLE HALF, RIGHT
As can be seen below, this feature "600 HEADLAMPS - CLEANING EQUIPMENT" is missing.
Engine no.: 276957 30 546710
Transmission: 722960 05 149018
Delivery date: 06 09 2013
07P - STEUERCODE FUER WERKSZUORDNUNG
10A - OIL OFFSET AMOUNT +1000 ML OIL
1U2 - SNOW GRID
212B - OP. INSTRUCT. AND MAINT. BOOKLET-ENGL. FOR USA/CAN
218 - REAR-VIEW CAMERA
222 - RIGHT FRONT SEAT, ELECTRICALLY ADJUSTABLE
232 - GARAGE DOOR OPENER WITH 284 - 390 MHZ FREQUENCY
240 - LED DAYTIME RUNNING LIGHTS
245 - TRIP COMPUTER / COMPASS
249 - INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
264 - LICENSE PLATE ATTACHMENT AMERICA
265 - LINES-NO.PLATE DISCONTINUED
275 - MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
280 - LEATHER STEERING WHEEL AND LEATHER GEAR SHIFT KNOB
284B - AIRBAG LABEL - ENGLISH FOR USA
287 - THROUGH-LOADING FEATURE
291 - PELVIS AIRBAG (PELVISBAG)
294 - KNEE AIRBAG
301 - ASHTRAY PACKAGE
309 - CUP HOLDER
30A - COVER WITH ADDITIONAL DAMPER ATTACHMENT POINT
342B - INSTRUMENT CLUSTER/HU LANGUAGE - AMERICAN
345 - RAIN SENSOR
348 - EMERGENCY CALL/SUPPORT SYSTEM
413 - PANORAMIC SLIDING SUNROOF/GLASS SUNROOF
427 - AUTOMATIC TRANSMISSION 7-SPEED
428 - STEER.WHEEL GEARSHIFT BUTTONS/SHIFT PADDLE PAINTED
440 - TEMPOMAT (CRUISE CONTROL)
442 - MULTIFUNCTION STEERING WHEEL (12 BUTTONS)
461 - INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
475 - TIRE PRESSURE MONITOR (TPM) HIGH LINE/MID LINE
486 - SPORTS SUSPENSION
494 - U.S. VERSION
4U4 - RADIATOR GRILLE WITH CENTER STAR
512 - COMAND APS WITH DVD CHANGER
518 - UNIVERSAL COMMUNICATIONS INTERFACE (UCI)
51U - BLACK FABRIC ROOF INTERIOR TRIM
536 - "SIRIUS" SATELLITE RADIO COMPLETE SYSTEM
551 - ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
580 - AIR CONDITIONER
584 - ELECTRIC WINDOW REGULATOR
59V - SPEED- + LOADINDEX 92H XL+94H XL
608 - AUTOMATIC HIGH BEAM SWITCH (IHC)
615 - BI-XENON HEADLICHT W.ACTVIE CURVELIGHT RIGHT-DRIVE
634 - DELETION - FIRST AID KIT
636 - DELETION - WARNING TRIANGLE
668 - PRODUCT PROT.F.TRANSPORT VEH. W/ TIE-DOWN HOOKS
690 - EMERGENCY SPARE TIRE (MINI SPARE)
705L - UNITED STATES (USA)
739 - TRIM PIECES - ALUMINUM
760 - AMG MULTI-SPOKE WHEELS 18" WITH MIXED TIRES
763 - RADIO REMOTE CONTROL W/ PANIC SWITCH (315 MHZ)
772 - AMG STYLING PACKAGE-FRONT SPOILER, SIDE SKIRT
799U - DIAMOND WHITE - METALLIC PAINT
7XXL - NORTH AND SOUTH AMERICA
804 - YOM 13/1
810 - SOUND SYSTEM
873 - SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS
875 - HEATED SCREEN WASH SYSTEM
876 - INTERIOR LIGHT ASSEMBLY
887 - SEPARATE TRUNK LID LOCKING
889 - KEYLESS - GO
900A - MICROFIBER
901A - MICROFIBER - BLACK/ANTHRACITE
909 - ALTERNATOR MANAGEMENT
916 - FUEL TANK WITH INCREASED CONTENT
917 - PZEV EMISSION USA
919 - AIRCON COOLING POWER PACKAGE
952 - SPORTS PACKAGE
954 - EQUIPMENT PACKAGE FOR AVANTGARDE VEHICLES
956 - AMG SPORT PACKAGE PLUS
986 - DEVIATING VIN WITH MODEL YEAR
989 - IDENTIFICATION LABEL UNDER WINDSHIELD
A20 - DIRECT START
A63 - FE TORQUE CONVERTER HOUSING-0
A64 - FE CONVERTER 0 MM
A68 - TRANSMISSION HOUSING WITH DEEP OIL LINE CONNECTION
A87 - U VALVE BODY ASSEMBLY WITH VGS 3
A89 - REDUCED-FRICTION
B03 - DIRECT START / ECO START/STOP FUNCTION
B09 - REFRIGERANT COMPRESSOR WITH MAGNETIC COUPLING
B12 - WHEEL REPLACEMENT TOOL
F204 - MODEL SERIES 204
FW - LIMOUSINE
G960 - TRANSMISSION CODE VERSION 60
GA - AUTOMATIC TRANSMISSION
HA - REAR AXLE
K15 - STEUERCODE FUER SERVICEINTERVALL 15000 KM
L - LEFT-HAND STEERING
M005 - VEHICLES WITH 4-MATIC-/ALL WHEEL DRIVE
M013 - ENGINE REDUCED PERFORMANCE
M276 - V6-GASOLINE ENGINE M276
M35 - DISPLACEMENT 3.5 LITER
N3A - STEUERCODE W50 FUER PPS-INT. VERWENDUNG
N4A - STEUERCODE W50 FUER PPS-INT. VERWENDUNG
P47 - AUTOMATIC PACKAGE
R02 - ALL SEASON TYRES
U10 - FRONT PASSENGER SEAT WITH WEIGHT SENSING
U22 - LUMBAR SUPPORT ADJUSTMENT
U26 - FLOOR MATS - AMG
U71 - DVD PLAYER WITH REGIONAL CODE 1, USA
VL - FRONT AXLE HALF, LEFT
VR - FRONT AXLE HALF, RIGHT
Transmission lock
Tank lock .......
Delivery date ...
SA code:
149U POLAR WHITE
1U2 SNOW GRID
294 KNEE AIRBAG
301 ASHTRAY PACKAGE
309 CUP HOLDER
345 RAIN SENSOR
494 U.S. VERSION
523 RADIO AUDIO 20
580 AIR CONDITIONER
803 YOM 12/1
889 KEYLESS - GO
952 SPORTS PACKAGE
FW LIMOUSINE
HA REAR AXLE
XLE HALF, RIGHT
Transmission lock
Tank lock .......
Delivery date ...
SA code:
149U POLAR WHITE
1U2 SNOW GRID
294 KNEE AIRBAG
301 ASHTRAY PACKAGE
309 CUP HOLDER
345 RAIN SENSOR
494 U.S. VERSION
523 RADIO AUDIO 20
580 AIR CONDITIONER
803 YOM 12/1
889 KEYLESS - GO
952 SPORTS PACKAGE
FW LIMOUSINE
HA REAR AXLE
XLE HALF, RIGHT
superangrypenguin (03-04-2018)
2012 C300 sport
What are the differences between 622 an 615? I have a 2012 with 615 (and 600) that I ordered with what was called at that time the "lighting package" and have always assumed, incorrectly it seems, that this was ILS. My owners manual says I have adaptive highbeam assist, active light function, and cornering light function. So what is missing? Smart fog lights?
I am in US and my 2013 W204 headlamp has the embossed lettering on it that says "Intelligent Light System" (see pics below). Does this mean I don't have the ILS option as offered in US?
I am here to learn and share what I picked from others. Would you be so kind enough to share what SA Code 622 implies?
Edit: My search for SA Code 622 yield the below youtube video. Audio is in German and description is in English. I have the same headlight switch as shown but still ...I'm lost!
Last edited by C0d3Sp4c3; 03-04-2018 at 10:23 PM. Reason: added info & youtube video
