Fuel pressure very high!!! C200 CGI
we noticed also these symptoms:
Sometimes is cold starts, the car vibrates as if it is going to shut off, after hitting the gas pedal the vibration will go away.
The engine oil smells like a strong fuel smell.
Exhaust smoke smells fuel as well.
Fuel mileage is very bad.
The spark plugs heads are black, noting that they were replaced a month ago.
so he told me that my car is giving rich mix which means that its taking fuel more than it should be.
Please tell me what I'm dealing with here as the mechanic told me to replace the rail fuel pressure sensor and change oil with filter.
Thanks.
my 2012 c300 have the similar problems. I can feel my car slow rapidly after i released the gas paddle and i was not using the brake.
I believe we have the same felling like you said: "feel lost in power when approaching a stop right before a completely stopping."
So dose your mechanic said this is caused by fuel pressure?
You might wanna check your transmission lubricant and inspect to see if there aren’t any vacuum leaks.
good luck
I will take the car tomorrow and see what will happen.
He changed the engine oil, updated ECU software, cleaned the spark plugs and the throttle body.
Strangely, it ran fine and the problem was solved temporarily until it accured again after 5 months.
