Android 10.25 Screen Unit
#228
Hello!
Does anybody know if it is possible to edit the original menu that the Android screen comes with. For example, to delete the ´Music' and ´Video´ links or change them to link to other apps?
I can´t seem to edit anything.
#229
I have an issue with the 10,25" large screen for W212 from 2010. when using android, I only have voice on front left speaker. Has anyone experienced similar issue? I am using AUX MMI cable (which came along with the unit) and at one point I had voice on all speakers and without changing anything it is back to one speaker (left front) and nothing I can do to make it play on all speakers. When using OEM all speakers works.
Also, I have an issue with boot, sometime I have the black screen (with the car logo on lane) on the right side and I need to touch the screen before the Mercedes Benz startup logo starts.
Please help, thanks a lot.
#230
Hi, this could be my first post so consider yourself special . I had this issue, I had messed with the order of the icons on the launcher and added the radio icon (which doesn't work on the newer unit anyway), as soon as I removed the radio icon in the launcher the problem went away...
#231
#232
#233
Double tap the icon I think, that moves it to the unused left side. Either that or tap the icon then tap a space on the left side.
#234
#236
normally I would agree but there are some pretty fundamental options in the "secret menus" that should never have been there in the first place(volume adjustments, boot animations, moving the order of the icons on the main screen etc.) If the radio option causes such an issue it should have been removed completely, not hidden away 😀
#237
#238
#239
Once you are in click Menu icon, follow what Raymond says in the above video. Take note of what he says about adding stuff (learned that one the hard way ).
#240
yeah, I went in there and was able to remove the Mirror Link icon because I have no use for it, but even after I placed Carplay to the front slot it still shows up on the 2nd page of icons.
EDIT: Maybe I can remove all, save, then re-add them one by one in the order that I want them. Just worried about goofing up the home screen and then needing a reset, which I dont wanna do now that I have 20GB of songs downloaded to Spotify.
#242
So when it's all said and done was it worth it getting the 10.25 screen unit? Eyeballing the latest 4gb ram.64gb storage one. I'm wondering if the whole thing becomes 'meh' after the novelty wears off. I know my pfl 09 63 could use a tech upgrade!
#243
Do you know if there is a way to re-assign the "Music" icon from the MP3 player to the spotify app? I know you can re-assign the Map icon to be Waze.
#245
Help needed please
ReHi guys,
Need to ask a favour please, while fitting my kids walked off with the screws and can't find them! Please can somebody tell me the size / thread of the 2 screws re-used from the original MB screen for the new mounting bracket, and also the screws to secure the screen to the bracket and stop the rattle noise.
Really appreciate the help!
#246
ReHi guys,
#247
Hi, I have 2 questions in regards to use of the screen to see if anybody can help
1) Currently, when I press the audio or video icon on the Home screen I get an error saying something like 'file not found' or 'unsupported media type'. Where can I go to set default apps for both of these?
2) Bluetooth, I want to pair a Bluetooth ODB-II adapter to Torque on the screen. BT is enabled, I can pair a mobile but Torque won't see the device (my mobile can see it). In Android Settings and Bluetooth, it only asks about auto connect etc. What am I missing, where can I go to pair the device please?
#248
#249
ReHi guys,
Motor-Talk.de w212 Martins thread
#250
So I bought a bluetooth OBDII scanner that plugs into my OBDII. This way I can see information such as RPM, speed, boost, temp etc on the screen. Except I can't get it to pair. When I go to my bluetooth setting, I see the OBDII on the list but when I try to pair, it won't pop up the screen to where I can enter the pairing code. Do you guys know of any bluetooth OBDII devices that do not require a pairing code?
This is the one I bought
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
UPDATE: Solved my issue
Found this app to pre program pin code for bluetooth connections. Well worth the price tag for what I'm trying to accomplish.
https://play.google.com/store/apps/d...con.btautopair
I purchased Torque Pro from the play store and here is a screen shot.
https://play.google.com/store/apps/d...g.prowl.torque
Not sure I like the interface of Torque Pro so I will keep searching for one that I like.
Nice writeup
I have almost the same screen as you but a newer version.
I also like the OBDII and Torque, but the screen cant find my OBDII.
As far i can understand you just downloaded the "bluetooth auto pair" and installet Torque?
Can you see the bluetoothconnection on the screen?
Could you please tell me exactly what you did?
