Android 10.25 Screen Unit
Old 03-22-2021, 06:34 AM
  #451
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Originally Posted by Ninjadom
Good. I’m gonna buy one from you next month. W204, 2011 version, NTG 4.5, right hand drive. Thanks.
Thank you. Very kind of you.
Old 03-23-2021, 07:14 AM
  #452
Ninjadom's Avatar
C63 2011, 125 Edition
Hi everyone, I’ve just got a few questions on the Android screen before I get mine. Mainly regarding Apple CarPlay.
1) Can the Android screen run split screen between the Android system and CarPlay? Or is it one or the other?
2) Can CarPlay run in split screen? So that you’ve got two CarPlay’s (music & maps) on screen at once?
3) While your iPhone is connected for CarPlay is your iPhone disabled or can it it be used as normal, as well as using CarPlay?
4) If my phone is connected for CarPlay but my daughter wants to stream her music from her iPhone, what happens? Does CarPlay accept and save multiple iPhones?
Thanks to anyone that can answer those questions.
Old 03-23-2021, 08:26 AM
  #453
1--no
2--See pic, see if its like this, new ios system+update the zlink will
3--when use carplay, audio for the apk carplay will come directly from car, cellphone play anything but will not have sound from phone
4--Only one phone, need bt to be connected to android bt, then you can use carplay
Old 03-23-2021, 10:23 AM
  #454
Ninjadom's Avatar
Thanks for those answers Chris!! Great help!!
Old 03-28-2021, 10:07 AM
  #455
Palom0's Avatar
2014 GLK300
Backup Camera on Android 10.25" Screen
My aftermarket backup camera view has a menu on the side with three icons (a circle arrow, a brightness lamp, and a button to move the active guidelines).
The first two don't do anything and the guidelines adjustment is useless as it gets reset every time I turn on the car back again.
As far as I could find:
- The aftermarket backup Camera generates the video image and a set of fixed guidelines (the three-colored guides in the pic)
- The OEM radio generates the center yellow guidelines (that move with the steering) and the 3 left-side icons you can see in the pic.
- The Android 10.25" Screen (RoadTop) puts all the above together and adds the car's parking sensors proximity status (car image on the pic)
Any idea if the three side icons can be turned off and if there's a way to make the guidelines adjustment permanent?
Thank you.
Old 05-01-2021, 02:04 PM
  #456
aznmode's Avatar
2010 c300
Still looking for V2 square version that has 2gb/32gb, home and back on screen button on the top right. If you are getting rid of yours, please let me know. Thank you!
Old 05-01-2021, 02:27 PM
  #457
aznmode's Avatar
2010 c300
Thank you.
Try going into the engineering menu by hitting the hangup + # + 1 buttons on the radio all at the same time with the car on the ON position. Hold it for 5 seconds or so til you get the engineering menu.
Then go to:
7 Hardware Setting
7.7 HU Parameter
7.7 SRVC Guide Line (go in this one)
Switich from x204 to none or the other way around
Exit out of engineering menu through the menus.
Test the backup camera.
You should only now have the grid lines from the aftermarket camera.
Old 05-01-2021, 04:34 PM
  #458
Palom0's Avatar
2014 GLK300
Then go to:
7 Hardware Setting
7.7 HU Parameter
I tried it today, but my Engineering Menu does not have "HW Settings" or "HU Parameters" (check the pics)
But still, what I really want is to make the moving lines alignment permanent. I like the yellow moving lines. As long as they are centered.
Old 05-04-2021, 02:22 PM
  #459
Ungarisch's Avatar
Tectitgrau S210
I have the V2 version that I'd get rid of, PM me if your interested.
Old 05-04-2021, 02:58 PM
  #460
aznmode's Avatar
2010 c300
PM sent. Thank you.
Old 05-04-2021, 03:09 PM
  #461
aznmode's Avatar
2010 c300
I think in this case you'll need to reposition the camera as it is probably built into it. If you were for example bought an after market camera, some will have you cut a wire to remove the lines. Or reallign the camera to also move the guide lines.
That would be a 2nd option is to buy an aftermarket camera that is attached to the trunk release and so is much centered. Also it points higher so you can see a lot more of the rear view not just the floor. That's what I went with even though I have a OEM camera already. I didn't like how the OEM points down too much. However, the guide lines on mine is stationary.
Old 05-09-2021, 07:23 PM
  #462
stefcep's Avatar
w202 c200 sport
I installed a universal DAB+ USB.
I managed to route the wiring inside the A-Pillar in and behind the glove box ( remove glove box) and out to the two USB cables that I keep in the cabin netting.
The DAB Z software worked but at first it asked me to scan but there was no obvious "scan" option in the DAB Z software. Turns out scan is performed by the magnifying glass search icon. Took me hours to work that out...
Some tips- the A-Pillar cover is held in place by metal clips: two at the base, one in the middle, and one at the top. It needs to slid up towards you about half an inch and then pried out. That last clip is held in place by thin plastic on the cover and the plastic breaks easily. Ask me how I know.
The antenna has a small adhesive copper strip on that must be stuck to bare metal to the A pillar for optimal reception. I scratched a tiny bit of paint off the painted A pillar and stuck the copper piece over it. I get 5 bars of reception.
After all the effort I am completely and utterly....underwhelmed. 32kbit/sec audio is rubbish no matter what the codec. This is on my HK too. FM sounds sooo much better. In your location the bit rate might be higher, but in Melbourne Aus, I would say DAB is waste of time and effort. Don't bother with it.
Old 05-09-2021, 07:27 PM
  #463
stefcep's Avatar
w202 c200 sport
The Android unit can turn off the moving parking lines through Settings-->System--> untick parking lines. No cutting needed. Again makes me wonder if for sure the android unit is generating the moving parking lines or the OEM unit.
We both already have an aftermarket camera that is centred on the trunk release. The moving guidelines (generated by the OEM system ?) are off centre. I'm actually thinking of re-positioning the camera to the original off to the side position to see if this centres the guidelines, when I find the motivation.
Old 05-09-2021, 07:46 PM
  #464
stefcep's Avatar
w202 c200 sport
I think this may be an Android software thing but I use both Here WeGo and Tom TomGo as my GPS apps because they both have offline maps, which for me was the main point of this unit.
I cannot get voice guidance to work unless I go in to Android Settings--> Accessibility-->Text To screen Output-->Google Text to Speech Service before i start the GPS app. Every single time I start the car.
Last Android I used was Android 5 and hated it so I am hoping someone knows how to fix it so that voice guidance "just works".
Old 05-09-2021, 08:02 PM
  #465
stefcep's Avatar
w202 c200 sport
Does anyone know what this downloaded service in Chinese characters is.
android
Old 07-07-2021, 05:00 PM
  #466
Merc1992's Avatar
2012 Mercedes c180 Coupe
10.25 Android unit from RSNAV
Hey guys, a mate has a unit he bought for his Audi S5 that he doesn't want. Wondering if that will work in my 2012 C180 coupe, if I can source the bracket and cables? Also, anyone know where I can source the bracket and cables?
Cheers
Old 07-08-2021, 10:42 PM
  #467
antiguangenius's Avatar
2008 S550 4Matic, 2007 GL450, 2008 C300, 2018 GLE63 AMG
Cheers
cant, different canbus data, MB and AUDI canbus is different, the MCU on the unit is also different
Old 07-08-2021, 10:57 PM
  #468
Merc1992's Avatar
OK. Thanks mate
Old 07-12-2021, 09:56 PM
  #469
razors7703's Avatar
2016 Audi A4
Audi head unit
OP here. Anyone selling their older / used later revision of the square corner one with 2 or 3gb ram. My v1 is finally giving me persistent out of memory warning. And I think it's time for a slight upgrade but I prefer the square corner version. Let me know.
Hi I'd be willing to sell my old stock screen
Old 07-13-2021, 12:34 AM
  #470
aznmode's Avatar
2010 c300
Do you know which version you have? Would like the 2nd revision with 2hg ram.
Old 07-13-2021, 12:49 AM
  #471
razors7703's Avatar
2016 Audi A4
Audi head unit
No idea not sure how to find out with it unhooked
Old 07-13-2021, 01:03 AM
  #472
aznmode's Avatar
2010 c300
Do you recall if the home and back button was on the top right? Also were you able to switch to mph or was it only kmh?
Old 07-13-2021, 01:15 AM
  #473
razors7703's Avatar
2016 Audi A4
Audi head unit
Not sure about the buttons. I know when setting up the mmi I could change mph. Are you talking about the screen? Attached a photo
Old 07-13-2021, 01:18 AM
  #474
aznmode's Avatar
2010 c300
Ah you're taking about the stock screen. I was referring to the 2nd version of the Android screen.
Old 07-13-2021, 01:21 AM
  #475
razors7703's Avatar
2016 Audi A4
Audi head unit
n.sorry I was talking about the stock screen. No idea what the version is of the one I installed
Quick Reply: Android 10.25 Screen Unit
