Android 10.25 Screen Unit
Here are 2 similar cool app so you don't need to mess with that small dot in the bottom left corner of the screen to expand the home and back button. I'm using the LMT Pie on xda since I also use it on my phone. The issue I found with the xda one is that you can't access accessibility option on your screen. You need to access this for the back button to work. The one from the play store will get you to accessibility during setup. But if you are rooted then the xda one will work right away.
https://play.google.com/store/apps/d....jun.simplepie
https://forum.xda-developers.com/sho....php?t=1330150
I have mine set to so I just swipe from the left or right side (mid section) of the screen and added a "recent app" button so I can get to my open apps quickly without going to home > apps. Also set up "quick Openquicksettings" button so I can quickly access BT, wifi, etc.
Android Screen on 2011 W204 pre FL
Thanks for posting this information... I just picked up a 2011 W204to use as a winter vehicle and realized it only has an aux input. So, From what I understand, even though I don't have a NAV system just the basic AUDIO 20 this system would be completely compatible with my car? i.e. full bluetooth capability and NAV?
C180 Kompressor (2008)
I don't think you can BT stream audio from your phone to the android. But I can check it again later as I might be wrong in this one.
It doesn't mess with or add extra features to your stock as it runs on its own. If you want to access your stock command you need to launch the radio from the android system so you can see your old system on screen and use the knob to navigate around it. You can still use your stock radio, BT talk, etc. If you want to go back to android just tap the screen again to go back to the android system. Some cases, the audio from the android won't auto switch from your stock (lets say you are listening to FM radio, CD etc) so you need to access your stock command screen and change audio to Aux so you can hear audio (Waze, youtube, etc) from the android side.
Party013 (03-15-2018)
Good to know! Thank you. I did pair my phone once to the android phone side but noticed it was very loud during calls and it was only working on 1 speaker so I unpaired and never let it reconnect.
#32
2015 C300 4Matic Sport
Does it improve the ipod connectivity (and player) or just uses the stock media interface? How are you getting internet access to download from google play and show maps in real-time?
Also, do you get firmware updates/fixes from the manufacturer?
#34
From what I understand is that internet acces comes from your phone, because you basicly connect your phone to the android screen and no longer the 'car'
#35
If your car had WiFi you can use that. There are things you can plug into your OBDII that gives you WiFi, monthly plan usually. Or use your phone as a mobile AP.
Now I have a question, a problem if you will. If I try to use Google Maps, it lags horribly. Maps itself I mean. Everything takes forever and when in navigation mode it lags behind really bad.
Waze is working well, but it loses GPS signal sometimes and thinks I'm somewhere beside the road. I put the GPS puck behind the screen beneath the dash.
#36
#37
I also recieved a flat and long antenna, which i didnt install. Maybe i need both?
#38
I put mine on the right. Left side is the video adapter box just in case it may interfere with the GPS. Did not get a flat long antenna in mine though so not sure what that's for. But my GPS is working fine. Will check later on the strength signal.
#40
I don't know what the 2nd one is but I only got the 1st pic in my kit and that's the one I'm using. Also, I've heard the GPS (1st pic) cannot be installed upside down. Have you checked with the seller what the 2nd one is for?
#41
New accessory
Installed Google assistant so I can voice dictate location, text entry, etc.
The USB port is not hot swap-able so you will need to plug this in prior to turning your car on.
It does produce some static sometimes so it's not able to pick up what I'm saying when that happens. But still better than not having a mic.
#42
I just received my package today. About to install it. But I also got the flat antenna thing, what is it? I don’t remember the YouTube install tutorial talking about it.
#45
And there is a setting somewhere where you can select if you want COMAND knob controller or not.
EDIT: Also make sure to select to correct settings for your car. Access those settings by tapping 5 times above "Navigation settings".
#48
Google Maps is laggy for me as well. Seems like it needs a powerful tablet or something. Waze is perfectly fine.
Question: how do you close apps? Do they close automatically when you switch apps?
My knob control scroll doesn’t work, whether I have the setting enabled or disabled. Clicking it works in the home money just fine but spinning it does nothing.
Also, I gotta invest in some aux filter to cancel out the interference I am getting. I’ve always has a buzz playing music and charging my phone at the same time, so now the buzz is always on since the tablet is powered by the car. 😢
other than that, I love it!
#50
