Android 10.25 Screen Unit
Old 04-04-2018, 05:44 PM
  #126
aznmode's Avatar
2010 c300
Originally Posted by Ungarisch
However, I dont think you really even need to upgrade the SD card. The 16GB card that comes with the units is already U1 rated, but the main issues is that even when you use AZNMode's Apps2SD application to move apps to the SD card, it reallty only moves the app from the 1GB internal system memory, to the 13GB "other" internal memory, not the external SD card. Also, when google maps downloads the local offline maps to SD card, you can only choose the 13GB internal memory to download to, not the external SD card. Spotify on the otherhand you can choose to download all songs to the external memory, so there's at least that!
You can use Foldermount if you want to utilize the physical SD card as app data storage. However it still won't copy everything over. I use combination of Move app to sd and Foldermount.
Old 04-05-2018, 06:00 PM
  #127
aznmode's Avatar
2010 c300
So I'm still having intermittent issue with Command screen not showing up in radio on the android. The seller sent me a fakra video connector but did not fix the problem. Decided to redo all the connected again. My theory is the block connector is getting crushed causing intermittent connection. Anyway, at least for w204 Pre FL, I have figured out the best way to get the block connector out of the way. Enough so there is no struggle getting the command back in. It literally just slid back in to place 95% on its own. I uploaded a video to share what I've done. Hopefully this also have fixed my issue.
The following 4 users liked this post by aznmode:
ahegazi (05-26-2018), Christophe (09-05-2018), PASHN8 (07-26-2019), rexiferp (05-01-2018)
Old 04-05-2018, 06:46 PM
  #128
Chris The Swede's Avatar
W222 S63L, ML/GLE350
Nice one....
Old 04-06-2018, 10:36 AM
  #129
maxnrelax's Avatar
2009 C300
Originally Posted by Chris The Swede
Nice one....
Order placed with CMK but no tracking info .
Old 04-06-2018, 11:16 AM
  #130
Email answered. No need to post that here.
Old 04-07-2018, 02:29 PM
  #131
deepthought66's Avatar
2014 Mercedes-Benz E350 4Matic Sedan
Originally Posted by aznmode
I haven't installed android auto as I didn't feel the need to since I can run more apps using with the stock android. Also haven't used tasker since I can't think of anything I want to autorun each power on. As far as other apps, besides the one's I've already posted here, I have not downloaded anything else. Do you have this unit or just thinking of getting it?
I bought the unit last month from Chris, and currently have it installed. After trying a ton of things, I think I'm a bit underwhelmed by this screen. Dont get me wrong; I think its a beautiful screen, with great resolution, etc. The rub is that after spending $600+ its still a screen. My use case is actually pretty simple. When I start the car, I want the screen launch either Android Auto or Carplay. I also want to continue playing music from Spotify or Pandora or whatever, and I want to change songs with the steering wheel. Finally, I want to voice search (mainly for navigation - "navigate to.....").
I can accomplish all of this with a $150 Moto Z Play, but not with this $600+ screen. No Android Auto to the best of my knowledge (since this is on Android 5.1), no Carplay (because the additional dongle - though it works most of the time - has multiple popups I need to deal with each time), no autoplaying of music from any "streaming" app. So net, net, this is just a very nice screen.... and thats it (for me). I just wish I could install Android Auto on this, and I'd be happy.
Old 04-07-2018, 02:40 PM
  #132
Ungarisch's Avatar
Tectitgrau S210
Carplay works fine, it launches as soon as you insert your phone into the lighting cable, no pop up, no screen to confirm. Android Auto is stil a no go and I cant find any info on how to get it to work because it seems like 99.95% of Mercedes buyers use iPhones...
Also, I currently have the unit auto-launch Spotify as soon as it turn on, yes I do have to manually hit the play button but that is about it.
Voice search from google works perfectly, and is about as fast as a Moto G. I use that exclusibely to launch everything navigation related, even to launch songs on Spotify. Yes you have to tap the mic button, but expecting Google voice search to be integrated into the steering wheel button is asking a bit much for out of this, as that is probably locked down by mercedes.
EDIT; this is an android unit afterall, it will require some initial software tinkering in the begining to get it to how you like it to be set up. its not a iphone where everything works as you had imagined it just out of the box. However, after you get it to how you like it to be set up, its a set it and forget it affair, you never have to mess with it every again. Infact I havent messed with mine in 1 week and it seems that now the unit boots up more like in 15-20 seconds for first boot instead of 30 sec when I was initially tinkering with it.
Old 04-07-2018, 07:14 PM
  #133
benzdude's Avatar
2015 C300 4Matic Sport
Have you tried any Andriod task automation apps to solve some of your issues?
Old 04-16-2018, 09:43 AM
  #134
maxnrelax's Avatar
2009 C300
Originally Posted by adro92
Did you double check the connections? On my car I had to do "B to B, and A/B to A".
And there is a setting somewhere where you can select if you want COMAND knob controller or not.
EDIT: Also make sure to select to correct settings for your car. Access those settings by tapping 5 times above "Navigation settings".
My command knob wasn't functioning as well . Shipped from the factory I received it as B to B and A/B to A.
I switched to A/B to B and B to A and it now functions. My car is an 09.
Old 04-16-2018, 12:55 PM
  #135
Yes, and it works decently well. Here's my setup (thanks to aznmode for suggesting a lot of these tweaks). Apps: Spotify, Pandora, Waze. Tasker for (a) autolaunching Tasker on boot, and (b) autolaunching Spotify on WiFi connect. Finally, LMT Pie for recent apps, voice search, and shortcuts to Spotify and Pandora.
The setup works ok, but my sense of being underwhelmed remains.
· Boot to music play time is agonizingly long
· Navigation is slow; Waze is faster than Google Maps
· Space limitation for apps require offloading to SD card, which then creates further performance issues
· Automatic audio switching doesn’t always work. I would have preferred for ‘manual selection’ that stays locked down
All said, I think I have tweaked and tested this screen as much as I possibly can, but the bottom-line in my opinion (irrespective of whether others agree with me or not) is this – if you want an upgraded screen only, then get this – it’s gorgeous! If you want your screen to have additional functionality like Spotify, Waze, Android Auto, CarPlay, etc. then you may want to wait for the next version (which apparently may come out in about a month or so – per Chris on another thread on this subject in the W212 forum). This screen desperately needs a better processor and a more recent version of Android.
Old 04-17-2018, 12:50 PM
  #136
95Sinned420's Avatar
2016 S550
I agree, those who say it’s not laggy or fast, just hasn’t been spoiled with fast devices lol
Just scrolling thru the maps on Waze or Google, with two fingers zooming in and out..is not fluid.
I still recommend it, it’s slow but still good enough.
It’s almost equivalent to using a 2-3 year old smart phone running the latest apps..hardware too outdated, barely meets the min requirements.
Old 04-17-2018, 01:44 PM
  #137
The new one will be much faster..
Old 04-17-2018, 01:56 PM
  #138
benzdude's Avatar
Sweeeeet! Andriod 8.
Old 04-17-2018, 06:17 PM
  #139
7 I think.
Old 04-18-2018, 03:09 PM
  #140
benzdude's Avatar
7 I think.
Andriod 7, 64GB internal and 2GB memory. 12 inch 1920x1080p touchscreen. SOLD!
Old 04-18-2018, 04:52 PM
  #141
2016 S550
Now what to do with he older one..? Had I known I would’ve waited.
Old 04-18-2018, 04:53 PM
  #142
benzdude's Avatar
Ebay. BTW i just made up those specs.
Your current system should be firmware upgradeable.
Old 04-18-2018, 06:39 PM
  #143
aznmode's Avatar
2010 c300
There's a check for software update in the setting I'm dying to press
Old 04-18-2018, 06:43 PM
  #144
aznmode's Avatar
2010 c300
I have to agree that this is not the best but I am glad there's at least an option. I have the stock command and about the only coolest thing it does is the auto open/close when the car is on/off. And I will probably ebay my android unit when the new one comes out or sell it here.
Old 04-18-2018, 07:15 PM
  #145
Cant wait for the firmware update too (if and when that ever happens). But I suspect this thing will continue to be slow as molasses thanks to the hardware.
Chris! Please get us an early adopter discount on the new unit when it comes out
And all said and done, kudos to Rock and the rest of the team who built this screen. Outdated/slow hardware (internals) aside, they have pulled off something truly phenomenal.
Old 04-18-2018, 07:55 PM
  #146
aznmode's Avatar
2010 c300
I honestly doubt they will be any android OS update on this ever. Maybe an updated launcher with additional features would be the only possible update.
Old 04-19-2018, 09:01 PM
  #147
Speaking of which....you know the Android 7 based version you found on AliExpress? The one that didn't come with the OEM-Type interface (like on ours)? Could the 'BCS Launcher' from this/our unit run on that one? I may be oversimplifying it, but at least in theory - this launcher should directly work, right?
Old 04-19-2018, 09:14 PM
  #148
aznmode's Avatar
2010 c300
Laucher is just an app on top of android OS. So in theory it should work. But the app needs to be compatible and optimized for android 7 for it to work properly or even work at all.
Old 04-19-2018, 09:43 PM
  #149
Yeah, true. Dammit! LOL
Oh well...
Old 04-20-2018, 02:32 AM
  #150
That is pretty close..
Quick Reply: Android 10.25 Screen Unit
