New style headlights for pre-facelift C-Class
Old Apr 16, 2018 | 05:19 PM
  #51
benzdude's Avatar
Top Answer: 1
2015 C300 4Matic Sport
Maybe in the summer start a new project to retrofit a morimoto h1 inside my headlights with a new shroud similar to the original oem style cone.
if you look at sides when driving you can see lots of reflections from the "chrome". It's almost like the current projector is too far back in the shroud and the flat square shape is blocking some of the light.
...or maybe upgrade oem lights with morimoto h1s and insert the neon bar under the current eyelids. Lolo.
Old Apr 16, 2018 | 05:24 PM
  #52
adro92's Avatar
C180 Kompressor (2008)
Low beams aren't fantastic, but they're not totally sh*t. I think I might just fit an HID kit and be done with it.
High beams exceeded my expectations tbh. Not that bad at all.
Old Apr 16, 2018 | 06:23 PM
  #53
benzdude's Avatar
Top Answer: 1
I agree it's not terrible and could be the bulb or just needs a proper alignment. Sometimes I get bored and need to experiment. I've never retrofitted a headlight before.
oh crap, i still have that blindspot kit to install.
Old Apr 16, 2018 | 06:45 PM
  #54
Mfawaz121's Avatar
C 180
2014 W204
New here, I know the link says up until 2011 models but is it possible this would fit on a 2014 c 180 W204?
Old Apr 17, 2018 | 11:12 PM
  #55
Akula's Avatar
2011 C-300
Originally Posted by benzdude
This, thank you so much for this picture, now im getting them.......love the way they look.
Old Apr 18, 2018 | 05:09 AM
  #56
Doa's Avatar
Doa
W205
no, overal shape is different and the connector is also not the same.
Old Apr 18, 2018 | 05:31 AM
  #57
adro92's Avatar
You would have to do some rewiring and get a pre-facelift bonnet and possibly bumper.
It's not impossible afaik, but i wouldn't recommend it. You could probably find some cool headlights for the facelift models.
Old May 22, 2018 | 10:12 AM
  #58
forevr5688's Avatar
2009 C300 Sport 4Matic
Out of curiosity, what are those four boxes with the wire sticking out. Is that for the Canbus system so it doesn't throw an error? Planning on getting these. Where did you guys mount them and can you post a pic? Thanks.
Old May 22, 2018 | 10:34 AM
  #59
benzdude's Avatar
Top Answer: 1
Those drive the leds/drls.
If you want a cheaper pair of these, i am selling my mint condition 2 week old set. I bought a new car.
PM me. if interested.
https://mbworld.org/forums/c-class-w204/707780-new-used-2011-w204-c300-sport-items-sale.html
Old Aug 18, 2018 | 12:56 PM
  #60
Kirkhutch's Avatar
2009 Mercedes C300
Any news pics?
Hey guys, about to purchase these for my red W204. Anyone have a pic of a red one with these headlights? Thinking about going with the black. Also, the white neon tube inside...anyone attempted to have solely this light come on as a DRL when the car is cranked? Seems like I’ll have to always turn on my parking lights to have them on during the day.
Old Aug 18, 2018 | 12:58 PM
  #61
Kirkhutch's Avatar
2009 Mercedes C300
Retrofit projectors
Also, anyone attempted at changing out the stock lens that comes with these to a better one like the Morimoto minis? Would love to see some cutoff line pics if so!
Old Mar 10, 2019 | 06:39 PM
  #62
deewee456's Avatar
C300
I purchased these lights and tried to install them today. The high beam, neon tube, and turn signals all work, but nothing from the low beam. Has anyone else encountered this problem? I tried both headlight assemblies land several different bulbs and it doesn't power on. I plugged the bulbs into the high beam to check and they work fine there.
Old Jul 1, 2021 | 03:34 PM
  #63
Drewwskii's Avatar
2015 C300
These headlights need to be available for face lift models
Old Jul 1, 2021 | 04:40 PM
  #64
antiguangenius's Avatar
2008 S550 4Matic, 2007 GL450, 2008 C300, 2018 GLE63 AMG
the shape won't allow it
Old Aug 1, 2021 | 09:40 PM
  #65
TheDroneGuy's Avatar
2011 c300
Hi !
I recently purchased H11 LED bulbs for my Mercedes with the same upgraded headlights. I have had a problem though, the LED headlights turn on and off (on for 5-10 sec off for 1-2 sec) ONLY when driving. Do you guys by any chance know if I need other bulbs more ballasts or anything that I am missing ? Could it be that there is some loose connections ?
Thank you for all your help !
Old Jan 12, 2024 | 10:39 PM
  #66
fidget's Avatar
W205 C43 AMG, W204 C63 AMG
I know this is an old thread. Was looking to see if any long time users of these Spec D lights have the same issue I'm seeing. Ive got them hooked up but getting random check parking light notifications on the dash.
Old Jan 13, 2024 | 12:01 PM
  #67
Demvang's Avatar
2011 C300 4Matic Sport
The LED resistor doesn’t do its job. Check its connection.
Old Jan 13, 2024 | 12:40 PM
  #68
fidget's Avatar
Roger that @Demvang
I have a few spare 55w8ohm and 55w6ohm resistors I can test out while I wait for their support to get back with me.
Old Jan 13, 2024 | 09:19 PM
  #69
fidget's Avatar
Used one of my spare resistors and fixed the issue.
For now I've swapped the iffy resistor that was hooked up to the parking light with turn signal resistor that the SpecD headlights came with. No more error. For now I'm up and running and will ask them for a replacement.
Was able to get the Spec D halogen set to work with my C63 that came with factory HID via a custom adapter so I don't have to cut into the factory wiring. Yay AliExpress and online wiring diagrams. I know its technically a "downgrade" from the factory Xenon HID but I need to replace the lens in one of the lights and figured this will tied me over. Upgraded the H11 that came with them to a set of Philips Diamond Vision to match the foglights. Bright enough and close to HID color.
