NO FUSE BOX, Where is it????????
Old May 26, 2018 | 05:36 PM
Prowla's Avatar
18 C300 4Matic.
I need to change the fuse for my AC, but the fuse box in the cockpit just isn't their, wtf?
my 2013 C300 should have one on the driver side end of the dash or so ever text I've read said, am I missing something??
this is total madness and I refuse to take it to the dealership service dpt to be charged $1.2 million just to replace a fuse.
Its just fuse!
can someone direct me to the secret location of this cockpit fuse box please....
Old May 27, 2018 | 01:09 AM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
next to the brake fluid container
Old May 27, 2018 | 03:08 PM
Prowla's Avatar
18 C300 4Matic.
thanks for the input JohnnyC but I know that one and the one in the one in the trunk, Im missing the 3rd fuse box (in the cockpit)
Old May 27, 2018 | 03:35 PM
JohnnyC's Avatar
should be #12 in the front box
Old May 27, 2018 | 04:11 PM
ItalianJoe1's Avatar
2003 CL 600
Should be here
Old May 27, 2018 | 06:01 PM
gamma300C's Avatar
2009 MB C300 Sport 4matic
You need to "pop" the cover with a plastic trim pry if you have one or a screw driver taking care not to bugger up the plastic. My '09 C300 only has 2 fuses in there, both w/o anything to do with the A/C.
Old May 27, 2018 | 11:15 PM
henry666's Avatar
Mercedes Benz C280 2009
read the user manual
Old May 28, 2018 | 08:08 AM
JimMBC300's Avatar
2008 C300
No Fuse box in cockpit
My 2008 C300 also has no fuse box in the cockpit. One under the hood and one in the boot, but none in the cavity at the side of the dash.
Old May 28, 2018 | 08:54 AM
2003 CL 600
It's listed as only on the facelift cars. His is a 2013 so it should be there.
Old May 28, 2018 | 10:02 PM
henry666's Avatar
AC fuse maybe in the fuse box under hood near driver side.
location may vary depends on year and model.
and the owner manual may also be different. :P
Old May 14, 2024 | 06:01 PM
Andy19's Avatar
MB C300 2013
Did you guys find out the location. I am looking for a passenger seat power control unit fuse.
thanks
Old May 14, 2024 | 08:23 PM
cvx5832's Avatar
325Ci, 325Cic, C300
After 6 years, I hope so!
Looks like you might get a reply since OP was active recently.
Old May 14, 2024 | 09:01 PM
Andy19's Avatar
MB C300 2013
I found it. On a different thread someone posted the actual diagram for the fuse box. Which doesn’t have instrument panel fuse near dashboard by the drivers seat. I’m posting it here if anybody needs it.
File Type: pdf
Old Dec 5, 2024 | 07:48 PM
Boogaloo13's Avatar
2009 MB C300 w204
Quick question
Quick question here does anyone know where the rear passenger side lamp fuses are or what number they are... all my rear lamp lights are out. Thanks in advance
Old Dec 5, 2024 | 08:05 PM
Andy19's Avatar
MB C300 2013
Check fuse 2,3,18,39,41. It should be one of them. If you can’t find them, check the fuse diagram I’ve attached in my previous post. What year and model is your car?
Old Dec 5, 2024 | 09:04 PM
TimC300's Avatar
I dont think the tail lights work like that.
I usually refer to this site for the fuse diagrams: https://fuse-box.info/mercedes-benz/...uses-and-relay
