2008 C300 Coolant Temp Sensor Location?
Was watching this video for replacing coolant temp sensor. But since mine is C300 I don't think this video applies.
I assume the sensor would be connected to the thermostat instead which is in the front of the engine. Can someone confirm this is where the sensor is at?
Btw, is this be the right part for my car (WDDGF54X68R016430)? https://www.fcpeuro.com/products/mer...sor-0041539728
Engine temp gauges started jumping up and down 3 days ago and AC just quitted blowing cold air this morning.
Update 08/29/2018:
Okay I can see why there has been so little info on where the sensor is located....it's next to IMPOSSIBLE to get a good look at that area.
To contribute to MBWorld, I've posted a video on how to locate it. At the end of video, the black sensor held by a silver ring plate (behind another wire) with a torx screw is where the sensor is located. Hope this help everyone in your future endeavor!
No coolant loss. Cyl head? You know a picture can say thousand words
btw, is there a better place to get this part...not sure how legit FCPEURO is and also I am located in US.
So this is suggesting the video in my original post is correct?
Dang....please tell me no.
Marked up a quick photo. I assume the Coolant Temperature Sensor is at the red circle not orange, right?
Or could it still be at the front of the engine nearby the thermostat?
Was watching this video for replacing coolant temp sensor. But since mine is C300 I don't think this video applies. https://www.youtube.com/watch?v=EIJuu9hpEgY
Update 08/29/2018:
W204 C300 Coolant Temperature Sensor Location
There’s a walk through to replace the sensor. All I can suggest is a 1/4 ratchet with the torx bit, a mirror(preferably one on an extension), a cover over the fender and some patience.
I would suggest to watch the video linked in my original post. Your enemy is not the stuff on top...your enemy is the space between the engine block and the firewall. You need a very small wrench. It's waaaaaaay down there. To identify, it has a small metal plate holding it in place, make sure you are not working on other part near it.
Be patient if you decide to do this. Good luck!
