2015 C300 spark plugs
Dealer recommended changing spark plugs for $550. When I pushed for details, the breakdown was $100 for 4 spark plugs ( Q-4-15-0038) and 2.5 hrs of labor.
Has anyone else replaced the plugs at 50K miles and what was the cost? I thought spark plugs had a much longer life than 50K miles..
You might take a look at the discussion of emissions warranty for your car and ask the dealer to reimburse the plugs as a warranty item. If they truly needed to be replaced, you would think the vehicle emissions were affected.
You might get better answers in the W205 section by the way.
Definitely a DIY job if you want to do it... A Search will bring up the procedure somewhere on the Web. The M276 engine says 60K miles for the plugs but I think that's because it's a Direct Injection engine..probably to soon. My M272 has the 60K interval and the iridium plugs look great at that mileage. Fairly inexpensive to change though but would invest in your own plugs/thin wallws socket. Torque is 16 NM-23 NM with the higher end preferred. A Torx (T30?) bit needed for the COP bolts.
Service "A" (10,000 miles or 1 year)
- Engine oil and oil filter change
- Replace dust filter
Service "B" (20,000 miles or 2 years)
- Replace activated charcoal cabin filter
- Rotate tires (if applicable)
- Flush brake fluid
50,000 miles or 5 years
- Replace engine air-filter
- Replace spark plugs
60,000 miles or 6 years
- Automatic transmission oil and oil filter change
120,000 miles or 12 years
- Replace fuel filter
- Replace coolant
- Replace cabin filter
- Flush brake fluid
- Replace coolant
