Heated Seat Plug - Can't Disconnect PLEASE—HELP!!!
It's small and very hard to see what needs to be done.
Pulling on it does nothing.
Pleas reply with a detailed answer.
like the seat cover job is like a 10 minute job if it wasn't for that stupid plug lol
How did you get the top two plastic pieces to turn at the top?
Someone should go jail for designing that plug connector!
I post results later.
lol i know i lost my mind too,they must have some "special Mercedes tool" to remove that. I tried using 2 pins and going from every angle it would not move after an hour i cut the ****ing wire and just spliced and soldered them together. ya post an update good luck!
I have no idea how to release them together.
I ended up buying a saw and cutting it in half. Vicious but effective.
I used vice grips to pull it out which pulled out the white plug as well. snap them together then insert.
When I installed the new cover, there are no metal rods on the left and right side like the old one. Design Change? The part number is same for passenger. Q. Did your new cover have rods on sides?
That plug looks like a pain in the *** to deal with.
Does anyone know how to remove the clip from the harness under the seat or what tool can be bought to remove it? I don't want to damage the female portion of the clip as it seems rather fragile.
Like someone said above. This job would take minutes if were not for that wire clip.
