Cheapest and Hassle-Free Way to Install ESL Emulator?
Old Jan 20, 2019 | 10:09 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Hey guys,
So I think the only repair I'll have to worry about (if ever) is the ESL/EIS lock.
I was wondering, what's the cheapest and easiest way to do this? I see some drilling and removing steering wheel column, and $500+ as well as replacing with (frankly, the garbage) Chinese motors. Any thoughts?
Old Jan 21, 2019 | 11:17 AM
GMTB's Avatar
2011 C300 Sport Calcite White / Black Anthracite
Hi,
There are several threads on the subject in this forum. There are some references to such in this thread. I had the MB dealer replace, no emulator, the ESL for $1,000 and change. Local independent shops would not touch the ESL.
From what I've read on the subject, do it before the ESL fails and is in a locked position. More work involved if it is locked. Hence the reason I bit the bullet and had mine replaced before failure.
https://mbworld.org/forums/c-class-w...ml#post7627172
HTH
Old Jan 21, 2019 | 04:06 PM
W204Motorsports's Avatar
2008 C350 Sport 4Matic Swap
An emulator is the only thing I would recommend.
https://www.ebay.ca/itm/MERCEDES-W20...bwvJ:rk:1:pf:0
I used this seller which was 30min away from me and he did an excellent job. All I had to do is remove the ESL and bring it to him with my ignition switch/key.
This was a few years ago and there are many more repair services available since its such a common issue.
https://www.ebay.ca/sch/i.html?_from...epair&_sacat=0
This fault is not always a bad motor, most of the time, its the actual circuit board that fails so replacing the motor won't do squat.
Old Jan 22, 2019 | 05:46 PM
dennish's Avatar
1992 MB 190E, 2016 MB C300
Thanks for the link ltwargssf. I think that I will do this procedure as a preventative measure. Good to have a honest, capable referal.
Old Jan 22, 2019 | 07:10 PM
Adi-Benz's Avatar
What's the difference between the $55 chips and $350 assemblies?
Old Jan 22, 2019 | 07:47 PM
It's not 350$, the emulators ( Looks like the OEM ESL but its all plastic) are just blanks, you can get them for 100$ or yes the chip is another option. the 250$ is the fee to program it. The emulator still needs to be programmed to your VIN.
Old Jan 22, 2019 | 07:50 PM
Adi-Benz's Avatar
So it's still around a $400 job huh
Old Jan 22, 2019 | 08:00 PM
Yeh, it used to be a 300$ CAD before the emulators got popular, now the demand is so high, the prices have increased. Still, a more reasonable option than getting stranded, paying 1.2k+ to the dealer and only for it to happen again down the road.
Old Jan 22, 2019 | 09:16 PM
meazz1's Avatar
C250 2013
Please educate me.
So, this ESL is guaranteed to fail?
I have 75k and it's a 2013 C250 sports.
Old Jan 22, 2019 | 09:34 PM
Originally Posted by meazz1
Please educate me.
Not to sure if the facelift models are affected by this issue.
Old Jan 22, 2019 | 09:41 PM
meazz1's Avatar
C250 2013
More "educate me" now, what is a facelift model?
Old Jan 22, 2019 | 09:46 PM
2012-2015 models. This was more of a 2008-2011 issue, however I'm curious if anyone with a post-2011 car had this issue.
Old Jan 22, 2019 | 10:43 PM
Knightmare69's Avatar
2010 C200 CGI
****, I've got a 2010 with over 100k km, probably should start preparing for this 🤦*♂️
Old Jan 23, 2019 | 12:13 PM
Adi-Benz's Avatar
Facelifts do not have the problem.
Idk what to do really, it seems like a lose-lose situation for the most part, I just feel weird about doing it.
Old Jan 23, 2019 | 06:39 PM
MBENZTECH's Avatar
W203 W212 W211 R53MCS
Facelift models do have the same problem. Here in my shop I always give my customers the choice of a reman unit from the dealer or an emulator. Most people go for the emulator, specially on older vehicles. Emulators are not plug and play, they have to be programmed to the EIS.
Old Jan 23, 2019 | 07:29 PM
MBpippo's Avatar
2013 C204 C250 Coupe
Facelift has daytime running lights whereas older W204 has fog lights. One of many differences, but an easy one to pick.
Old Jan 23, 2019 | 07:44 PM
Well the 2011 switched to led running lights but still was a prefacelift.
Old Jan 23, 2019 | 08:50 PM
Adi-Benz's Avatar
Im suprised cause I haven't seen a single person who has a facelift on these forums report it, only people with prefacelift especially 08/09
Old Jan 23, 2019 | 10:48 PM
MBpippo's Avatar
Wasn’t aware of that. Thanks for letting me know.
