Driver underside plastic cover. What's the correct install supposed to look like?
Should the plastic corner be tucked inside the floor lining?
If not, this DIY https://www.pelicanparts.com/techart...eplacement.htm (or others you might find on that website) might provide you with some helpful images.
I feel like there is still something wrong with the fit. For instance, the grey foam strip at the bottom of brake-light-switch cover is showing through on mine (see pic above) whereas on the Pelican Parts site no foam is visible.
So yes, there is a Philips head screw under the red hood latch handle. However, it just holds the latch module in place with the underside plastic piece. It was my entire underside plastic piece moving down with the pull-down motion of the latch, not just the module, so it couldn't have been just that.
There is, however, a metal retainer on the underside plastic piece (to the left side of the latch) that went missing from my car. See attached. Without that metal retainer the entire plastic piece moves with the pull-down motion. Mystery solved.
I think the fact that we might use different references for different parts, it makes it difficult for others to hone in on what we are talking about... (Although that part is not what a "tongue and groove" represents, I would have called that a "tongue and groove"!
Now I wonder if the two hooks (light blue circles) actually hook on something? Or only rest on top of other parts?
