Drive belt noise C300 W204
I searched for moths and replaced belt and idlers and still I had a noised which would come and go at idle and all idler pulley flapping back and forth, worse when battery voltage is low.
Replaced the idler and now no noise and tensioner idler is stable.
FYI my daughter 18 replaced mine under my tuition and coaching to gain some mechanical experience, blue sleeve and hands at end of the video.
Also need a spline drive and Allen key
https://www.aliexpress.com/item/4001...archweb201603_
The way you test if the bearing has seized is to remove the drive belt and install small screwdriver into the front of the alternator this jamming up the inner shaft from turning, at this stage the drive pulley should turn by hand in one direction and be locked in the other direction.
A failed bearing result is the pulley is locked in both directions which is what you will find with your car.
If you want to replace only the pulley it is quite easy just need to pop the black cap of the pulley and check the p/n of the original pulley mine was INA 535 0165 10 which is on ebay then I brought the two tools required from aliexpres and my 17year old daughter swapped it in over under my tuition.
Replacing the alternator has its merit depending on milage if it is worth the extra expense, my C200K had the odd noise from the front at idle from about 100,000km and we replaced it at about 125,000 by the time I figured what was really the problem.
Ps, when you get to NZ make sure you drive down the South Island through central Otago check out all the hydro dams, beautiful drive.
It runs perfect and dead quite no odd sounding noises.
