2013 C350 Fuel Composition Sensor "Flex fuel sensor"
Old Nov 18, 2021 | 10:31 AM
Jeff Handley's Avatar
2013 C350
Good morning,
My 2013 C350 is giving me the P0179 code. (fuel composition sensor high input)
Has anyone changed this sensor ?
Where is it located ?
Anyone have a part number ?
Thanks,
Jeff
Old Sep 29, 2023 | 04:51 PM
JettaRed's Avatar
Veteran: Army
Bump. I got the same code.
Old Sep 30, 2023 | 05:05 PM
JettaRed's Avatar
Veteran: Army
Correction. My code was P0178.
Turned out to be water collecting in my driver’s side floorboard after days of rain. The water migrated into the connector of the wires going to the flex fuel sensor. My scanner said the sensor was shorting to ground. When I disconnected the connector, water came out. I blew everything out with compressed air and reconnected everything. I cleared the codes and it didn’t come back. I will post some pics soon.
Old Sep 30, 2023 | 05:39 PM
alynch's Avatar
2020 C300, 2013 C250, 2000 Boxster S
A few years ago, while tackling corrosion on electrical connectors, I liberally sprayed everything with DeoxIT. Excellent product. It removes all the surface oxidation and coats the contact surfaces with a thin layer of conductive material. You might want to pick up some and treat your connectors.
Old Feb 13, 2024 | 04:26 AM
dpell's Avatar
2013 C300 w204
@JettaRed How did you identify the flex fuel sensor? There was no corrosion anywhere in the connector blocks? My carpet got soaked 2 months ago (then I cleaned my sunroof drains) now I'm getting the
P 0178 code, plus P062B - Internal Control Module Fuel Injector Control Performance. I hope it's just a matter of details of the wires but I'm worried I may have to replace the connector blocks and modules themselves. I just saw your post and haven't taken out the floorboards yet to see.
Can you post pictures of the connectors you had to dry out?
Old Feb 13, 2024 | 06:46 AM
JettaRed's Avatar
Veteran: Army
Sorry, I forgot I had posted that I would post pics. Here's my thread that shows everything.
https://mbworld.org/forums/c-class-w...78-solved.html
Old Feb 13, 2024 | 10:34 PM
dpell's Avatar
2013 C300 w204
@JettaRed Hey, THANKS SO much for meticulously recording and posting all of this invaluable information. So helpful. You've saved people alot of time and money here. Many thanks!
Old Feb 13, 2024 | 11:13 PM
JettaRed's Avatar
Veteran: Army
You're welcomed.
Old Feb 14, 2024 | 02:20 PM
cvx5832's Avatar
325Ci, 325Cic, C300
Nothing to add, only that DeoxIT is some of the best contact cleaners I've ever used. Absolutely love the stuff.
Old Nov 28, 2024 | 07:17 AM
JettaRed's Avatar
Veteran: Army
Well, it's been 14 months since the fix and no recurrence of the problem.
