C350 W204 Ignition Switch Back Ordered
Describe your problem here so the group can decide. May not be as bad as the dealer is making it out to be.
https://vepro.ca/product/mercedes-w2...gaAlxUEALw_wcB
ESL failure always has a fault code that relates to the signal to the lock. Sometimes the relays will click inside the ESL if the motor has failed and the lock is already at its ends stops. Either fully locked or unlocked. When the motor fails and the lock is not end at its end stops the ESL detects the fault and completely disables the lock never to work again. Only way is replacement. 95% of the time its the ESL at fault. But I have seen lately the EIS units are starting to fail as these cars age.
a quick check of actual values on xentry combined if any faults will quickly tell you which part has failed.
Good luck
I replaced the motor for $20 and about 2 hours in my driveway but most people do the emulator.
