ATF109 adapter- Which quick connect fits this?
I just want the quick connect itself.
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Oh, and it definitely is not a standard air fitting connection.
For example, when doing the final "hot fill" on the 722.9, you can close the ball valve and quickly pop off the hose at the quick connect and check if the fluid is under or overfilled without threading the fitting out and making a mess. It's not a deal breaker by any stretch, but if you have the fitting on your adapter, you might as well use it.
Can cut the hose shorter obviously and add some clamps. Pull the hose off from the pump side when done filling, then with the car running open the valve until the fluid stops coming out then close the valve back up. Thats my plan at least.
