Engine light on my 2010mercedes c class
Old Sep 26, 2023 | 05:29 AM
lucas12's Avatar
c class
Hi guys looking for your help only just joined not great at internet stuff, the problem I have is my engine light come on and the code reader says manifold absolute pressure/ mass air flow throttle any advice on what the problem is would be greatly appreciated thank you,
Old Sep 26, 2023 | 07:21 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W204 forum...
Old Sep 27, 2023 | 03:51 PM
TimC300's Avatar
What is the exact code its showing? What are the symptoms with the vehicle, if any?
Old Oct 2, 2023 | 07:35 AM
lucas12's Avatar
c class
Engine light
Thank you for your response the code I’m getting from my code reader is p2074 and the car is slow at accelerating they are the only symptoms thank you
Old Oct 2, 2023 | 07:54 AM
gamma300C's Avatar
2009 MB C300 Sport 4matic
Has the air filter box (rearmost top engine cover) been removed recently ? If so check rubber ring seal to throttle body is correctly seated and not torn. Check MAP sensor for leaking hose, corroded connector. Link might help..
Old Oct 2, 2023 | 08:17 AM
TimC300's Avatar
What engine do you have? I should have asked that previously.
Old Oct 2, 2023 | 08:57 AM
lucas12's Avatar
c class
Engine light
Thank you I will check the things suggested and get back to you thank you so much for your reply
Old Oct 2, 2023 | 09:01 AM
lucas12's Avatar
c class
Engine light
the engine is a 2.1 cdi thank you
Old Oct 2, 2023 | 09:03 AM
lucas12's Avatar
c class
sorry is a c200 cdti
