Excess water vapour coming out of the tailpipes?
Hi all, another post here regarding a potential issue with my car (2013 C350). As the title says, I've recently noticed an excessive amount of water vapor coming out of the exhaust of the car, especially when sitting at idle. This is obviously noticeable at night, especially at drive thrus with the lights of the cars behind me shining through the cloud of steam. The weather outside has been around 15-18 degrees c (or 59 - 64), which is cooler than in the summer months although I don't see why this cooler weather would make the steam coming out of the exhaust more noticeable, especially when other cars on the road are not producing any steam. Please correct me if I'm wrong but this does not appear to be a sign of burning coolant/oil mainly because the steam is only visible outdoors and not noticeable in my garage. Nor is it visible during start up. I'm planning to take the car to a euro car mechanic next week but would still like to hear the severity of this issue and whether or not I should stop driving the car until my appointment at the mechanic. Could this be a serious problem with the engine, or could a simple tune up solve this issue? Thanks.
Received 1,634 Likes
I would say nothing is wrong. Condensation just happens and you are seeing it being burned off. Now, if you rev the car and there is a white cloud every time and doesn't seem to diminish, then it sounds like a coolant leak. BUT, you should also get a CEL for misfires. Check your coolant level and oil and make sure there is no water in the oil. As I have said before, get yourself a scanner specifically for Mercedes, either iCarsoft MB V3.0, Launch Creader Elite MB, Foxwell, or BlueDriver, and scan for code (which may be present without a CEL).
If your coolant is low, you can also get a to check for exhaust gases in the coolant. If detected, then you should be concerned. That is usually due to a blown head gasket or a cracked head.
But for now, to put your mind at rest, get a scanner and scan for any codes. EVERYONE who owns a Mercedes (or Audi or VW) should get a scanner for their brand of car. That's the first mod I ever make to my cars.
If your coolant is low, you can also get a block tester to check for exhaust gases in the coolant. If detected, then you should be concerned. That is usually due to a blown head gasket or a cracked head.
A blown head gasket will blow “smoke” like a fogger machine. Like I said before, probably nothing is wrong.
Probably normal and not an issue. If oyu fluid levels are fine and not going down, and cant smell oil or coolant its probably just water/condensation coming out. I dont drive many miles and im always seeing moisture out the tailpipes. Not in summer heat but when its cooling down, even rainy humid days.
I searched for how to tell if a car is burning oil or coolant, other than the fluid levels go down, and came across this which makes sense:
Burning oil creates a lot of thick bluish white smoke.Burning coolant is more of a bright white smoke, excess fuel is darker, almost black smoke.
I also noticed the following while looking around in the engine bay. does that look like a significant amount of oil on this part of the engine and what could that piece be that appears to have broken off? This car has seen multiple mechanics yet none of them appear to have noticed this part.
I've had a couple of cars with either blown head gaskets (1995 Ford Windstar) or a cracked head (2005 Audi A4). When coolant leaks into the cylinders, you will see a cloud of white "smoke" and definitely smell the coolant. The car will also run badly and cause the CEL to come on immediately due to misfires. If you are having neither of these (and your coolant doesn't go down noticeably after driving a mile), then it is unlikely a head problem. To put your mind to rest for less than $40, get this (as I linked above):
Also, as I said above, get yourself a scanner and scan for codes. Don't go cheap, but get one that will scan all of the modules for your car. If there is a problem, it may not cause a CEL (yet), but there will be a code. If there are no power codes (PXXXX), then you're fine. Believe me, if you are running rich, having misfires, have a bad O2 sensor, etc., there WILL be a code.
I cant tell anything. Stick your phone down in there and snap some photos of the engine. I do it all the time, thats how I saw my oil filter housing leaking oil.
Now that you have them recorded, I would try clearing the codes and see if they come back. Did the mechanic clear the codes for you?
These cars are so sensitive to battery conditions, a weak or disconnected battery can throw a bunch of codes. Make sure your battery clamps are tight and there is no corrosion on the terminals.
- The most common cause of a U0100 code is a faulty battery. If the voltage in your battery drops too low, it can affect network communications, which can cause your vehicle to come back with a U0100 code.
- DTC U0111-00 Lost Communication with Battery Energy Control Module “A” will come on – Incorrect Battery Energy Control Module (BECM) harness routing causing tension on connector C4YB01D resulting in high resistance/open circuit.
- DTC U0168 Lost Communication With Vehicle Security Control Module. When monitored this DTC with the ignition on, battery voltage between 10 and 16 volts, ignition Off Draw (IOD) fused installed.
