2012 Mercedes C250 coupe breather issue
What's involved in replacing the breather valve or whatever may need replacing in the breather system? I haven't been able to find any good videos/descriptions of what's required to get to the breather hoses. Some mention removing the air intake box and intake manifold (ie .a lot of work). Others say you can get to it from below the engine.
This is the only post I see that's not the same engine but looks similar.
Breather hose replacement
Richard
here's a few diy post examples:
https://mbworld.org/forums/c-class-w...-fix-tips.html
https://mbworld.org/forums/c-class-w...acement-2.html
Before airbox removal
Air intake manifold
Throttle body
After air intake manifold removal
Oil in the air intake tube
Bottom of air intake manifold
Crankcase breather
Air intake manifold
Throttle body
Crankcase breather
check out my other thread going - https://mbworld.org/forums/c-class-w...e-oil-cap.html
I have the same issue as you now. Replaced the low pressure PCV (under the intake manifold) there is a high pressure PCV built into the valve cover. My other thread has all the info on it.
I am waiting on a new valve cover to swap it and see if that fixes the crankcase pressure at idle. Will report back.
ant
What would be the average odometer reading when the C250 coupe breather issue surfaces?
(I have a C250 coupe - which my new wife loves)
ez
it is likely due to lack of maintenance and or lots of idling. I would just keep an eye on it and monitor the blow by. Once your oil fill cap no longer is sucked it and is hopping and jumping around, I would say a new valve cover is needed.
Ant
Ant
Thanks again,
ez
I purchased it from autohausAZ - https://www.autohausaz.com/pn/150513...saAqqwEALw_wcB
i also upgraded the intercooler and put new charge pipes on. I’m glad I changed the charge pipes when I did at about 100k miles they were starting to show their age.
I also had oil in the charge pipes when I removed them. This is common on forced induction cars. The only way to fully Eliminate oil getting into the intake system is installing an oil catch can.
