Freeway stall (?)
What happened??
I believe this is caused by computer networking.
Many shops including dealers may replace tons of parts for zero result and no warranty. Be sure to refuse estimates done without any TESTING.
Get a complete scan report to hopefully provide clues - I think this is a stealthy unlogged condition... not too uncommon.
There are too many stories here of people who've unloaded the parts canon on their cars at great cost, and yet they still have the problem, or it turned out to be something simple they overlooked at the start.and theyve spent a heap of cash on parts they didn't need.
Time, research and a scan tool will help as well as a good independent MB mechanic.
I'd suggest like CaliBenz that you most likely have an ECU or harness/wiring fault. Preparation prior to diagnosis is the key. Start with checking battery (incl terminals) and alternator to make sure everything has adequate voltage. 11.7v minimum engine off and 13.7v engine running. Then the ground wires and connections to make sure there's no corrosion and they have a good contact base.
After that, you can then start on more specific areas depending upon where your research and advice sends you. Its essentially a process of elimination. Best ot luck.
My face is blue from saying this over and over, get a Mercedes-specific scan too!
Many recommend the LAUNCH Creader Elite 2.0 BENZ, though iCarsoft and Foxwell are also recommended. Any of them should be under $200 and less on Amazon. You will not only know exactly what codes were thrown, but sometimes simply stopping and restarting the car will not work, while using the scanner to clear the codes will. Clearing codes will not fix the root cause of any fault, BUT may get you back on the road far enough to get home or at least a safe place.
Your car is 14 years old. You need the right scanner more than a brand new car (though I recommend one for new cars, as well).
In any case, I ordered the LAUNCH scanner and will update. Thanks for all the responses.
Were you braking and then the warning lights came on?
The vacuum hose is the one on the left with white numbering all over it.
P0606 - Component Y3/8n4 (fully integrated transmission control control unit) is faulty.
B18CC01 - The output for actuator "Fuel filler flap" has a malfunction. There is a general electrical fault.
9dd015 - The output for the mirror heater has a malfunction. There is a short circuit to positive or an open circuit.
I also checked the alternator and battery and got the following data:
Alternator ID - 3
Battery - 13.66v
Calculated Alternator Torque -5.5
Electrical Fault Alternator - NO
Engine - 690 RPM
Mechanical Fault Alternator - NO
I don't know how to check the transmission with the scanner, but I got to the part where is showed the data. Do I drive around with the scanner plugged in and print a report??
Alternator ID - 3
Battery - 13.66v
Engine - 690 RPM
The fuel filler cap is probably leaking and letting in air. Try and few layers of plastic wrap around the inside of the cap and reseal it and see what happens.
- Did you have all electrical consumers (A/C, lights, COMAND, etc.) off when measuring the voltage?
- How many miles on the car?
- When was the transmission last serviced (i.e., fluid and filter change)? Your car is 14 years old and should have been serviced at least once, if not twice. Tranny service is required based on either miles or age.
2. 133k
3. Transmission fluid and filter were replaced at 80k service (March 2018).
I had the same thing happen on my 2004 SL500 while going through a construction zone in rush-hour traffic. Not fun trying to get to a safe place when all the shoulders are blocked. Shortly after that, I had my conductor plate replaced by the dealer. I think it was around $1700 at the time. But that did of course include a tranny service.
Isn't the code for the fuel filler cap having to do with it locking/unlocking the filler door? Does the door lock and unlock when using the key fob? I'm assuming it is if your getting gas.
Mines a 2010 and records show trans serviced at 40,000 miles, 80,000 miles and now its a little over 150,000 miles and Im just waiting for nicer weather to do it myself, along with replace the rusted trans pan. My Maintenance manual says it should be serviced every 40,000 miles.
Awhile back I was pulling into my parking spot in the back, i do a large half circle then back up into my spot which is on an incline. Soon as I stepped on the brakes to stop and put it in reverse it stalled, oddest thing. Hasn't happened again since. Maybe this was just an odd one time issue. few months ago my red battery light was showing on the dash, was driving me crazy trying to figure it out. hasn't happened since.
last thing, when you mention going down an incline im wondering how much gas you had in the tank, if it was very low maybe something with the fuel pressure, Im totally speculating on this one.
"B18CC01 - The output for actuator "Fuel filler flap" has a malfunction. There is a general electrical fault."
I was searching around and was coming up with a fault at the filler door. The lock on it not working.
I don’t have a lever or button or anything to open the fuel filler door — I just push and it pops open if the car’s unlocked. So kinda confused about that fault message.
I feel like the transmission service should’ve been done at 120k! My mechanic blew it. Maybe I’ll have my new mechanic do it and replace the battery while I’m at it.
Gas was about 3/8 full for the incident.
I will keep an eye on things and pray this was just a fluke like your battery light.
Thanks.
I think the fuel filler flap actuator is mounted to the back of the filler door assembly. Its what lock/unlock the door from being opened. I know my fuel door wont open unless the car is unlocked. looking at the parts diagram it shows a harness at the filler door (900). And part 440 is the emergency pull located in the trunk if theres an electrical problem so you can get the door opened.
Try your door, see if its always opened.
photo os a used filler door on eBay, can see the electrical connection.
