C200 2010 blueefficiency white smoke from engine bay
I have tried searching, and found results indicating "radiator clip", expansion tank cap and the diesel filter heating/seating thing as likely culprits for a coolant leak. What is confusing is that I cannot see any leaks, and the smoke seems to be coming from the exhaust manifold side of the engine(passenger side, EU/US)
There are no signs of oil in coolant or coolant in oil.
Three times now it started smoking during the last two weeks(~400km) I top it off with fresh coolant, all is well for a few days and then it does it again.
I cannot understand how a constant leak can make this happen, as she drives fine for days and suddenly decides to blow smoke. So then im left with the cap for the expansion tank, can that be the culprit? Somehow spraying the engine bay with a fine mist of coolant, not leaving any wet spots?
TLDR: White smoke from engine bay some times, car using coolant, what can cause it?
There is actually a kit used to evacuate the air from the coolant system AFTER you drain the coolant. Part of the process is to vaccum the system using an air compressor and see if the vacuum holds. If it does not, you have a leak.
Check this on Amazon...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Will try to take a pic if it happens again. I guess my plan of attack is to start disassembling the cooling system looking for cracks, don't want to keep feeding her coolant and hope for the best.
For the price, something like this might work better since the adapters are specific to different coolant tanks. It's also a system pressure tester.
As for the leak I found, seems like a hellish location to work on. I hope someone has some insights on this. It is definitely a coolant line, assuming it has to do with the cabin heater
While it could be condensation, that seems like a poor design and unlike Mercedes. Is there normally a cover over that area?
As far as the coolant hose, I can't help you there as I am unfamiliar with that engine. At least if you take it to a shop, you can point out the suspected problem and ASK THEM TO CONFIRM before repairing or replacing anything.
Good luck.
Good luck.
Yeah, there is a engine cover over there. But still a weird one, will keep an eye on it
