Vibration When Accelerating
Old Jan 13, 2025 | 05:45 PM
hmclaughlin67's Avatar
2008 C300 4Matic
I have a 2008 C300 4Matic. When I accelerate lightly, the car gets like “waves” of vibrations. It sounds and feels almost like a pulsing sound you’d hear in a horror movie. This used to happen lightly and be a little noticeable, but somewhat recently it got worse and much more frequent. Now it happens more frequently, and I also noticed the RPM’s reflect the feeling now when they didn’t use to. When the pulsing is bad, you can visibly see the RPM needle going up or down (or only up if accelerating a little harder) by 200 RPM each time. This never happened before, and it’s very unpleasant to drive and worrying.
I know I need new engine mounts, but it still doesn’t explain the RPM part of it, and my mounts aren’t that bad. They have a slight vibration at idle when the engine is cold, but when warmed up it’s basically absent.
Could this be from low transmission fluid? I noticed that it’s much worse when the car is warmed up than when cold. I have everything I need to do a drain and fill + filter change on the transmission, minus the fluid and fill adapter I still need to pick up. To me it kind of sounds like a torque converter, but up until a few weeks ago it shifted so smoothly and never did this so I believe it may just be low on fluid, but not really sure.
Edit: On that note as well, what transmission fluid do you guys recommend? Genuine fluid or has anyone had any luck with that Fuchs Titan 4134 stuff?
Old Jan 15, 2025 | 10:48 AM
2008 C300 4Matic
Just bumping this back up to see if anyone has any ideas before I start following my gut.
Old Jan 15, 2025 | 03:54 PM
Shadedmoon's Avatar
Mercedes C230 1997 W202
Hey,
Sounds like an annoying problem that has been creeping up over time.
With these symptoms it can be easier to diagnose from a video.
A hunch is bad ignition coil? Electronics tend to show issues when warm more so than when cold.
A misfire due to an erroneous ignition coil could lead to rough running under accelerqtion and sense of vibration, though from the front.
If it is from the rear, as weight transfer go to rear end of the car during acceleration, the drive syatem, rear tyres condition, balance and fit (if loose) could play a part.
These are all just some ideas that may help you along the way.
Edit: If rpm fluctuates as much as 200 rpm, lnly things I could think of is engine misfire, slipping, or erroneous rpm indication.
Old Jan 15, 2025 | 05:54 PM
2008 C300 4Matic
Originally Posted by Shadedmoon
Hey,
I put on new coils a few weeks ago using OE parts. Problem was occurring before that as well. Unfortunately I’ve covered all the obvious things already, the last one left is the transmission service. I just bought the car, unknown history, so I bought everything needed to drop the pan and change the filter. I plan to drain the torque converter and transfer case as well to get as much fluid out as I can. I still need to buy the fluid but otherwise I’m ready to see if that helps. All genuine parts from Mercedes as well.
I doubt it’s wheel related as well, and it’s certainly a drivetrain issue and not speed related. I did narrow it down today in that it only happens in 4th gear and up, which makes me think the transmission service might help a lot.
Old Jan 16, 2025 | 04:06 AM
Shadedmoon's Avatar
Sounds like a tranny service can help. It is often needed anyway. Hopefully it is just that and no mechanical issue or electrical e.g. conductor plate.
Good choice on quality parts.
Old Jan 16, 2025 | 09:05 AM
JettaRed's Avatar
Veteran: Army
The Fuchs stuff is OE, meaning it's what Mercedes fills its jugs with. Previously it was sold under the Pentosin name (and still is in some quantities). I've used it and when I last had my tranny serviced by the local Mercedes dealership (they let me provide my own parts), the tech said that Pentosin/Fuchs is what is in the Mercedes bottles.
Just make sure you get this stuff and NOT the FE.
Old Jan 17, 2025 | 04:51 PM
2008 C300 4Matic
It seems to only happen when in drive. Revving in park doesn’t recreate it, neither does reverse. Here’s a video I managed to get.
File Type: mov
Old Jan 18, 2025 | 07:33 AM
Shadedmoon's Avatar
If OK in park and only on the road, indicates issue with slipping transmission? In park and neutral the transmission is disengaged.
Another thought, hve you tried go into sport / manual mode? Will the car show the gear it is in when driving? Perhaps the gears are cycled, up/down, that could also impact the revs to fluctuate.
Old Jan 18, 2025 | 09:11 AM
2008 C300 4Matic
I believe it is the transmission as well for that reason. And the gear stays solid, it shifts like normal it just does that weird rumble almost.
Old Jan 18, 2025 | 11:00 AM
Shadedmoon's Avatar
Ok. Perhaps read codes at home or at a garage. Sensors of various type could impact the running too. May be a cheap fix if lucky.
Old Jan 18, 2025 | 11:05 AM
2008 C300 4Matic
I don’t have an MB specific reader as of yet, but I have an Innova 5610 and I couldn’t get any codes off it. I’m picking up the fluid shortly and will see if that helps.
Old Jun 2, 2026 | 04:53 AM
415cpa's Avatar
GL450
Hello, did you ever figure out the issue? Did changing the transmission fluid stop the vibrations?
