why am i still getting P0002 after replacing HPFP
Old May 1, 2025 | 05:22 PM
cadman33619's Avatar
W204 C250; W167 GLE 350
Hi all,
about 1 mo ago i was on the interstate and stepped on it to pass. Car buckled a bit then lost power and would not accelerate when pushed. Engine light came on. Checked codes and got P0002 - fuel volume regulator control circuit range/performance. After research, i took it to a shop and had the high pressure fuel pump replaced ($1k for the part, $1k labor, $200 misc).After that, all was good until last week. Same thing happened and engine light came on again. Mechanic suggested i use my code reader to erase the code then drive and see. Today same thing happened. Guess i wasted my money on the HPFP.
Any idea what the issue could be?
2014 C250 72,900 mi
Old May 1, 2025 | 07:10 PM
JettaRed's Avatar
Veteran: Army
Let us know where you are located.
When you took the car in, did you tell the shop to replace the HPFP or did you describe the symptoms and let the shop determine the cause?
Old May 2, 2025 | 10:08 AM
i asked them to replace the HPFP but they agreed that this was the cause.
i'm located in Tampa, FL
Old May 2, 2025 | 11:45 AM
JettaRed's Avatar
Veteran: Army
Can you post your VIN or precisely which model you have (204.XXX)?
Unless you are absolutely certain of the cause of the problem, I would never tell a mechanic to replace an expensive item -- let them figure it out. But keep close eye on what they say and do.
Of course, doing your research first is important.
Old May 2, 2025 | 12:07 PM
VIN WDDGF4HB0ER312953
Old May 2, 2025 | 02:02 PM
JettaRed's Avatar
Veteran: Army
Is yours the M272 engine?
I tried to find test procedures for the P0002 error in XENTRY Simulation, but cannot. Sometimes you need to actually connect to your car and run diagnostics. XENTRY/DAS is really the best way to go if you are going to do your own diagnosis. XENTRY will walk you through all the troubleshooting steps. It is almost essential to have someone that knows what they are doing when using XENTRY.
Many of us here have memberships in the BenzNinja Club where Peter will remote into your laptop and run diagnostics on your car. He can then help pinpoint the problem. I recommend him because you have already thrown $2200 at the "problem" and it is still not fixed. If you are going to own a Mercedes, you need his help. Especially for older cars where the parts canon will cost more than the car.
Old May 2, 2025 | 02:06 PM
JettaRed's Avatar
Veteran: Army
BTW, your car is a 204.047. Your engine is an M271. Get your full datacard here: https://www.lastvin.com/vin/BPr5q2v3L07AXmxML
Old May 2, 2025 | 02:26 PM
looking into the BenzNinja Club now. Its a bit confusing but it sounds like its exactly what i need. I've also been looking for someone who can disable the eco start/stop on my wife's 2020 GLE 350... BenzNinja Club has that service.
Old May 3, 2025 | 05:32 AM
RobertR728's Avatar
2014 c300 w204.080 3.5 v6
What's confusing? I have his membership maybe i can help clear thing up.
