Weird groaning / scraping noise under braking (when coming to a stop)
Old Jun 14, 2025 | 11:38 PM
TorontoC350's Avatar
2013 Mercedes Benz C350
Hi all, hope everyone is doing well. For a while now, I have noticed a strange noise coming from the front left side of the car. The noise sounds like some kind of groaning / scraping and happens at lower speeds, as the car comes to a stop. I have also noticed that the noise is more pronounced when the brakes are applied fully (100%) than when applied, let's say 80% or less. Another interesting thing that I have noticed is that in the past, the brakes would usually squeak as the car came to a stop. However, that squeak has now been replaced by this noise.
Several attempts at hard braking seem to temporarily fix this issue for some reason. After doing some digging on the internet, I came across a video posted by someone having the same issue but on a 2008 Ford Fusion with some people claiming that this type of noise could be caused by low brake pads or warped brake rotors. Others that I've talked to have said that the cause might be the slider pins within the calipers, while my mechanic said that the cause may be the brake caliper, something he later retracted after being unable to create the noise while the car was idling. The front rotors / pads were replaced approx. 20,000 KMs / 12,500 miles ago. I've also attached a video to show what the noise sounds like.
Many thanks in advance.
File Type: mov
Old Jun 15, 2025 | 04:30 PM
cvx5832's Avatar
325Ci, 325Cic, C300
Two ideas jump at me from your description. Thank you, btw, as most folks give much less.
First is you have a sticky caliper or slide pin that ‘s caused the early demise of one or both pads. Squeaks when the backing plate starts touching the rotor. It starts to growl when it’s completely on the back plate. Did this on my old CBR.
Second is the more obvious - wheel bearings. Test it. 20-30mph sweeping turn, left and right. If it gets louder for one vs the other, the bad bearing is opposite the turn you’re taking.
Old Jun 15, 2025 | 05:40 PM
Appreciate your reply. I think you make very good points. I have not been able to confirm the condition of the inner brake pad. However, I was able to grab the following image (from a few weeks ago) which appears to indicate that the front left rotor may be in good condition, i.e. not damaged by contact with the backing plate or a damaged pad. Although the opening captured in the photo below is rather narrow and I can't be 100% sure. With regards to your second point, I have not noticed any abnormal sounds when driving on highway off-ramps, which in some cases consist of 90 degree turns. However, I will pay more attention the next time around I am making one a hard turn in either direction. I do plan to take the car in to another mechanic to perform a more thorough inspection of the front brakes. Is there anything else I should ask him to check for (besides the brake pads and rotors)?
Old Jun 15, 2025 | 06:19 PM
cvx5832's Avatar
325Ci, 325Cic, C300
Pads will tell the story. Take pictures of both pads, of both wheels. From there we can easily determine if it’s the pins or piston that’s getting stuck. If you’re allowed to poke around in there, get the piston and rotor too, although not necessary.
Old Jun 15, 2025 | 06:23 PM
cvx5832's Avatar
325Ci, 325Cic, C300
And since we’re waiting, might as well play the guessing game. A 125k-miles CA car should have spotless brake components. I have 256k and they still look new. I do, however, bleed the system ever 3 years if that helps.
No, my money is on a tech that forgot to change it12k miles (kms?) ago.
Old Jun 15, 2025 | 06:41 PM
Thanks, unfortunately I am unable to lift the car and check those parts on my own but I will specifically ask the mechanic to show me the condition of the front pads and rotors. I think there was a misunderstanding because my car now has around 126,000 KMs / 78,000 miles. I actually bought the car about two years ago at 106,000 KMs / 66,000 miles. The front rotors and pads (as well as the front strut assembly) were replaced by the previous owner's mechanic in order for the car to pass safety and so that I could have the car registered under my name. In other words, the front rotors / pads are two years old or approx. 20k KMs or 12.5k miles. I know that this was a terrible mistake and that I should have bought the car 'as is' and completed the repairs at my own mechanic. However, this was my first purchase ever and there were many things that could have been done better / differently.
Old Jun 15, 2025 | 07:50 PM
cvx5832's Avatar
325Ci, 325Cic, C300
Life. I get you
Old Jun 15, 2025 | 09:53 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Don’t beat yourself up. You’re learning and on a Mercedes that may not be the easiest place. Your car doesn’t have a lot of miles, so it’s probably not too serious.🤞🏻
But you will have to acquire the tools (like maybe a 15” portable frame lift) needed to get under a W204 or it’s going to get expensive to outsource service.
These cars are very durable and reliable when maintained.
Old Jun 15, 2025 | 10:33 PM
Thanks, appreciate the kind words. There are a few things I'm trying to address on my own but I currently live in an apartment building which sort of limits what I can and cannot do in terms of servicing this car.
Old Jul 10, 2025 | 08:12 PM
Hi all, thought I'd update everyone on this matter especially seeing how many people just disappear after not finding a solution in the forum. I brought my car in to my mechanic the other day for a couple of things, with the brake noise being one of them. Both he and his apprentice, with the latter being the person who worked on the car, stated that they did not hear any such noises under braking. I did explain to them that the noise is fairly audible under light braking as the car comes to a stop. However, they said that they didn't notice anything. After getting in the car myself, I did notice that the noise wasn't very audible anymore, and approximately 24 hours later, it appears to come and go under light braking. One difference that I notice from the day before is that the brakes are now a lot more squeaky than before. Not sure if the mechanic had role in any of this but he also mentioned that the brakes, along with the pads, appear to be in good condition.
Old Jul 11, 2025 | 12:11 AM
W205C43PFL's Avatar
Sigh so that means the mystery continues...
