Incoming call ringer sound VERY LOUD!
Old Nov 12, 2014 | 11:23 PM
radiojon's Avatar
2015 C-Class C300W4
Whenever I have my phone connected via BT, the integrated ringer sound through the speaker system on an INCOMING CALL is INCREDIBLY loud and quite unnerving. I tried turning down the volume on the steering wheel as the call is ringing in, and that turns it down temporarily, but the next time a call comes in, it's back to ear-splitting levels.
Any idea on where to adjust this setting? I've found controls for the outgoing volume and reception volume, but those only seem to apply to the volume of the phone call itself (you can adjust the caller's voice to be louder or softer), but not the on-board, BT integrated ringing sound effect.
It also doesn't seem to be connected to the ringer volume on my phone, either. I've also changed that setting to a very low setting (and even vibrate) and it still doesn't affect the ringer volume through the BT system.
Help!
- Mark
Old Nov 13, 2014 | 12:38 AM
joshg1001's Avatar
2017 E300
You mentioned you tried the steering wheel volume control. Did you try the main volume control next to the shifter?
Old Nov 13, 2014 | 01:29 PM
radiojon's Avatar
2015 C-Class C300W4
I've tried setting it via both as the ringer is coming in. In fact, it's the first thing I always do, because the ringer is SO loud, I keep worrying the speakers will blow. But it always seems to revert back to the maximum volume.
Old Nov 13, 2014 | 03:11 PM
Merlin1's Avatar
W205 C200 Sport Premium Plus. October 2018. 1497cc with 48 volt battery eq
Does this help....
Old Nov 13, 2014 | 03:43 PM
bwoodbmw's Avatar
E90 335i
I don't believe that will change the ringer volume but could be wrong
Old Nov 13, 2014 | 03:58 PM
Merlin1's Avatar
Looking at it again I think you are correct.
Old Nov 13, 2014 | 04:14 PM
radiojon's Avatar
2015 C-Class C300W4
I tried adjusting these settings, but it only seems to pertain to the caller volume on either end, not the ringer volume.
Old Nov 13, 2014 | 06:22 PM
joshg1001's Avatar
2017 E300
That is strange. On my W204 C class, the radio volume controls the ringer volume when there is an incoming call, and it stays that way for the next call.
But these kind of volume glitches aren't uncommon in Benz cars. Again on my C class, the radio volume defaults to a loudish setting every time you start the car, no matter what volume/mute you had it on before shutting off.
Old Nov 13, 2014 | 10:13 PM
Leslielp's Avatar
2020 CLA 250 4Matic Black
I think you have done everything correct.
My suggestion is to either remove the current Bluetooth phone and set it up all over again.
If this fails to fix, try hitting the "OK" button after you have adjusted the incoming ring volume.
Fortunately I have never had this problem with any of the Command/Phone setups on my MBs.
Old Nov 14, 2014 | 03:25 AM
DBOC205's Avatar
W205 C250BT
Have you contacted your dealer? Maybe there's a fault, but at least you could try it on another car if you take it back to the dealership.
Old Nov 14, 2014 | 07:32 AM
Glyn M Ruck's Avatar
Super Moderator
There has to be a way to set the default ring tone volume unless their is a software bug with a fix on the way.
On older units in stock radio or Comand you had to adjust the volume while the event happened and it remembered the setting discreetly. e.g. while the Nav lady spoke or the Phone rang or on Audio.
Old Nov 14, 2014 | 12:27 PM
tgrx1901's Avatar
C200 AMG Line Premium Plus
This earlier thread (from 2007!) seems to be about the exact same problem.
https://mbworld.org/forums/c-class-w...ng-volume.html
One thing I noticed in it was:
"Ringing volume is set up strictly through your blue tooth phone... if your phone supports blue tooth 1.0 or higher, then by decreasing the ringing volume on your headset profile or bluetooth profile will automatically decrease the ringing volume on whatever bluetooth headset you are connected to. That is the only way this can be done, there are no settings within the vehicle to regulate ringing volume."
Might be worth a try.
Old Nov 15, 2014 | 12:02 PM
utsenmo's Avatar
2015 C400 4Matic
have you....tried to adjust the ringer volume on your phone? it could be set on max on the BT device.
Old Feb 6, 2015 | 11:58 PM
aleaton's Avatar
2014 E 350 & 2015 C 300
Ringer Volume to loud.
We have a 2015, C300 paired with a Samsung S3 android phone. We have the same issue with an extremely loud ringer. This is not the phone ringing but the car ringer. We had 2011, C300 and E350, no problem with this phone. We have a 2014 E350, no problem. We took it to the dealership, they called Mercedes. They still do not have a solution. This is a safety issue as the ring is very startling. I know MBZ is more about Apple IOS but there are a lot of Androids out there. They have a system bug that needs fixing.
Old Feb 7, 2015 | 03:55 PM
mbinnl's Avatar
S213 220D
On a German forum a guy had this adjusted by his dealership. There is a (German?) manual to make adjustments to the Audio20 CD settings in a hidden menu of some kind. I'm trying to get more details of this. My Dutch dealership also adressed this as a safety issue with The Dutch MB organisation. See what comes out of this.
Old Feb 7, 2015 | 09:51 PM
aleaton's Avatar
Loud ringer.
Thanks for the info, I will be very interested in what you find out.
Old Apr 17, 2015 | 09:30 AM
notabenex's Avatar
C63 W205 17' + W205 C250@brabus + NSX 95'
Any news?
Old Apr 17, 2015 | 10:21 AM
CO2010's Avatar
2015 C300 RWD Sport Premium
Originally Posted by Merlin1
Does this help....
That's Odd. I only have two options. De-authorize and details?
EDIT: Found the additional options.
Old Apr 18, 2015 | 07:16 PM
aleaton's Avatar
Loud phone ringer in 2015 C300
I adjusted the both volumes as per the MBZ instruction above. It does nothing. This is a serious safety hazard Mercedes needs to address. My wife and I nearly jump out of our skin every time we have an incoming call. It is very, very startling.
Old Apr 18, 2015 | 10:45 PM
chicagofan00's Avatar
C400
What kind of ring tone do you have set on the phone? I've got music set for my ringtone on my iPhone 6+ and it comes through the speakers at a normal volume. Maybe change the ringtone on the phone and see if it makes any difference.
Old Apr 19, 2015 | 10:02 AM
mdsbuc's Avatar
2013 BMW 335i Msport, 2012 Mustang GT
Seems like it would be worth a try. Btw, as a relative newcomer here, it's good to see a "familiar face" from "the fest."
Old Apr 19, 2015 | 12:08 PM
C400
Old Apr 19, 2015 | 12:41 PM
mbinnl's Avatar
S213 220D
Nothing so far: had my car in for service, but they couldn't find any submenu for the Audio20 CD settings. This summer I will be in Germany, will give this a try with a German dealership.
This issue seems to be there for all non-Apple phones.
Old Apr 19, 2015 | 04:49 PM
tgrx1901's Avatar
.... This is a serious safety hazard Mercedes needs to address.
A tad over dramatic I'm afraid!
Old Apr 20, 2015 | 10:57 AM
l3it3r's Avatar
Veteran: Army
2015 W205 C400 4Matic
I use an iPhone 6 Plus, set to a music ringtone, and the in-built car ringtone scares the living crap out of me when it rings. It's horrible.
