Tail light /bumper alignement
Old Feb 23, 2015 | 03:31 PM
omnidive's Avatar
C300 model 2015
So I visited my dealer who wanted to show me how they fixed this issue on one of their c300 in stock. The fix was perfect. All they do is unscrew the screw holding the slim bumper part going up the side of the light and insert a spacer and everything lines up properly. The screw is from inside the trunk on both sides and is an easy fix.
MB according to my dealer has not issued a formal fix protocol but I think if you insist enough with your dealer they can and should fix it---a perfect seam is what one expects when buying an MB!
Old Feb 23, 2015 | 03:40 PM
cidtek's Avatar
C300 4Matic Tenorite Grey
Can you give me the name of your dealer so I can my service guy to call him.
Does this fix where the bottom side of the taillight sticks out a lot?
Old Feb 23, 2015 | 03:46 PM
omnidive's Avatar
C300 model 2015
Mercedes Rive sud in brossard quebec Service manager Serge Lavallee
Directeur de Service
450-672-2720 ext 160...and yes it fixes everything. I'll have mine fixed same I have winter tires taken off---assuming this damn winter does end!
Old Feb 23, 2015 | 04:15 PM
BlackjackM's Avatar
2018 E300 Lux, 2006 Corvette Z51, 2015 Mercedes ML350 (wife's)
I figured it was an easy fix- when I get mine and if I need to do it I'll take pics for a DIY.
Old Feb 23, 2015 | 04:51 PM
cidtek's Avatar
Thanks and it's even Canadian so even better yet.
Old Feb 23, 2015 | 05:29 PM
emilryba's Avatar
C3004matic, BMW 328d xdrive C w206 AMG line
Can you provide with some pictures where is the screw located in trunk?
Old Feb 23, 2015 | 09:09 PM
omnidive's Avatar
C300 model 2015
sorry he just explained it to me....it should be mid-way on the side of each light--the side nearest to trunk lock. I think it can be accessed via the trunk-its the screw that secures that slim part of the bumper that joins(imperfectly) to the trunk top.
Old Feb 23, 2015 | 09:58 PM
emilryba's Avatar
OK. Thanks !
Old Feb 24, 2015 | 10:29 AM
BoboPolo12's Avatar
W205
Sorry if this is obvious, but does that mean the bumper doesn't have to be removed at all to fix it? Also, what size spacer?
Old Feb 24, 2015 | 01:26 PM
omnidive's Avatar
C300 model 2015
tail light bumper fix
Correct...bumper not removed . Screw access from inside trunk(probably have to remove plastic cover inside)...spacer size I have no idea..I assume might be 4-7 inches long but thickness dunno..
Old Feb 25, 2015 | 12:24 PM
Patentesq's Avatar
2015 C300 Sport, 4MATIC, New York
Can you please send a picture of what the bumper looks like after the repair?
Old Feb 25, 2015 | 01:17 PM
omnidive's Avatar
C300 model 2015
I have my appointment in March same time to get winter tires off...I'll try to take good pics of before and after and post them here.
Old Mar 18, 2015 | 01:06 PM
napickard's Avatar
C300W4, GLC
Bumper alignment fix?
Is anyone aware if there is an official fix to the bumper-tail light alignment issue? When I was at the dealer two weeks ago all the inventory still had the issue.
Old Mar 18, 2015 | 01:20 PM
omnidive's Avatar
C300 model 2015
no official MB fix circulated to dealers that I've heard of.
My dealer has come up with their own fix. I'm having mine done next week and I'll post back . They did show me what the fix result looked like on a c300 in inventory and it should be 100% good.
Old Mar 18, 2015 | 02:50 PM
Patentesq's Avatar
Any information you can get from your dealer on how they did the repair, would be much appreciated. I want to pass this on to my dealer.
Old May 3, 2015 | 11:03 PM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
Ask if there is a recall code or something or "bulletin #" that's normally the best way to tell other dealers
Old May 4, 2015 | 08:31 AM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
There is no bulletin, and current production has not eliminated that "step" between the panels. It's a simple fix that just involves some small shims to even out those panels, and most dealers will do it as a warranty item when requested.
