Lowered on Vossens c400
Old Apr 2, 2015 | 02:38 AM
whoLEEoh's Avatar
2015 C400
So I have a c400, I have another thread opened up about my brother-in-law tuning my car. We are still in process of doing the calibrations but he has successfully cracked into the ECU so that means tuning with no piggy back. I can't say where he worked to prior but I can say he was a tuner for one of the largest mercedes benz aftermarket tuners in the world. I'll post up more info here when we dyno.
My car is lowered on Vogtland springs and sitting on Vossen CVT gloss graphite wheels in 20x9 and 20x10.5 (forgot offset will post up when I remember) wrapped in 235/35/20 front and 275/30/20 rear. I had to run a 5mm spacer upfront because i wanted no clearance issues at all.
So I know I know, let's get to the good stuff.
These are a couple of quick pics i took after installing the wheels and tires, more to come so stay tuned.
Old Apr 2, 2015 | 04:53 AM
vic viper's Avatar
S213
Pretty daring to go 9" with spacers up front, I have 8.5 with no spacers and it is pretty damn tight when turning sharply
Then again I am a bit lower than you.
Old Apr 2, 2015 | 08:57 AM
HRD2PLZ's Avatar
2018 E43 AMG
Nice Job! Looks great!
Old Apr 2, 2015 | 12:34 PM
e63hb's Avatar
2012 E63
Looks really nice on the 20" !!
Old Apr 2, 2015 | 07:33 PM
Capt Slo's Avatar
2019 C43 Sedan and 2020 Volvo V60 CC
Looking pretty sweet!
Old Apr 2, 2015 | 09:07 PM
bwoodbmw's Avatar
E90 335i
so far I think thats the best aftermarket wheel I've seen for the w205.... same as vic viper right? Looks great, very interested to hear how the tuning goes.
Old Apr 3, 2015 | 10:16 AM
amanuuh's Avatar
2014 CLA 45AMG , 2015 C63 (W205)
Im loving what I'm saying when people mod their C class. Looks great bro. Considering youre in Florida I know who youre working with haha Its going to be good.
Old Apr 5, 2015 | 07:03 PM
Merc3n's Avatar
C400
Originally Posted by whoLEEoh
So I have a c400. My car is lowered on Vogtland springs and sitting on Vossen CVT gloss graphite wheels in 20x9 and 20x10.5 (forgot offset will post up when I remember) wrapped in 235/35/20 front and 275/30/20 rear. I had to run a 5mm spacer upfront because i wanted no clearance issues at all.
Do you have airmatic? If so how is the ride with the lowering links?
Old Apr 10, 2015 | 02:20 PM
Fmxomar's Avatar
C300
CAN YOU PLEASE POST THE OFFSET ?? ALSO HOW BIG IS THE SPACER IN FRONT
Old Apr 10, 2015 | 02:46 PM
vic viper's Avatar
S213
55 rear and 44 front most likely
Old Apr 26, 2015 | 01:27 PM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
looks good. Would be nice to see pics from diff angles.
Old Apr 26, 2015 | 10:38 PM
whoLEEoh's Avatar
2015 C400
was out on the farm today and took a couple of pics, will post when done editing them. This is one of the ones I did.
Old Apr 29, 2015 | 08:51 AM
whoLEEoh's Avatar
2015 C400
lakeside
Old Apr 29, 2015 | 11:11 AM
Ed99's Avatar
E63s AMG
20s fit very well with the w205. Do they sit flush?
Old Apr 29, 2015 | 09:46 PM
angeloxnet's Avatar
15 Mercedes C400, 12 Mercedes C250 coupe
Can you share if you changed any spring pads or anything other than the springs? normally the rear is higher and not level, any additional info would be appreciated
Old May 3, 2015 | 11:07 AM
angeloxnet's Avatar
I have Vossen VFS1 20x8.5 and ET45 and 20x10 ET55 coming off my C300.
will it fit direct on the c400 4matic? currently with stock heigh with airmatic but plan to lower with links soon. Do I need spacers up front?
Old May 3, 2015 | 11:51 AM
vic viper's Avatar
S213
It will work, no spacers needed, but you might want to look into your tire dimensions as the W205 use larger tires than the W204.
Old May 3, 2015 | 08:28 PM
angeloxnet's Avatar
running 235/30/20 F and 275/25/20 R currently
Old May 4, 2015 | 12:58 AM
vic viper's Avatar
S213
Should work fine
Old May 4, 2015 | 01:04 AM
angeloxnet's Avatar
Originally Posted by vic viper
Should work fine
sometimes i wonder what would happen if we didnt have ppl as helpful as you :P
Old May 7, 2015 | 11:48 PM
angeloxnet's Avatar
Should work fine
The Vossen VFS1, don't clear my calipers
it touches, guess i need a 5mm spacer.
Old May 8, 2015 | 12:21 AM
vic viper's Avatar
S213
Really? I have tried CVT, VFS-2 and CV3 and they all fit allthough they barely clears the calipers.
Must be a slightly different design in the VFS1, sorry about that.
Old May 8, 2015 | 06:29 PM
angeloxnet's Avatar
rears also do not clear either with a 55 ET on VFS1, in fact they scratch the back but only on the insides. Needs a 3mm spacer as it touches the clip that holds the brake pad.
I am now exhausted lol. from trying.
Did I mention I am running 20x8.5 and 20.x10? i wonder if thats a bad thing on 4matic, hear conflicting opinions
Old May 9, 2015 | 03:13 AM
vic viper's Avatar
S213
Yes, it is the very same dimension I have been running, no problems front or rear.
Rim width has no negative impact on 4WD but you must choose tires with as close outer circumference as possible.
Old May 11, 2015 | 12:22 AM
angeloxnet's Avatar
what tires do you have in the back?
running 275/25/20
