Touchpad favorites and open touch area not responding
Old Apr 11, 2015 | 11:12 AM
amp512's Avatar
Toyota Camry
I am having issues with the touchpad "favorites" button and the open touch area for input or selection. The touch pad is not responding and I am not able to press the favorites button. The back button and quick audio track change/radio station change buttons are working.
Old Apr 11, 2015 | 11:20 AM
amp512's Avatar
Toyota Camry
Actually even the back button and the track/radio station change can't be pressed from time to time.
Old Apr 11, 2015 | 12:49 PM
ManiacGT's Avatar
BMW e89 Z4 sDrive 35i & MB S205 C200 AMG Premium Plus
Back to the dealer, sounds faulty. How old is your car/what build date?
Old Apr 11, 2015 | 01:22 PM
amp512's Avatar
Toyota Camry
Car was shut for like 30 minutes when I came back all 3 buttons started working again and I can select things by pressing the touchpad but still no swipe left/right/up/down or can't input text. My C300 is only 3 weeks old with around 425 miles but the build date is August 2014.
Old Apr 11, 2015 | 01:47 PM
ManiacGT's Avatar
Try cleaning the surfaces. It's a touch pad and therefore it could get messed up by conductive gunk?
Old Apr 11, 2015 | 05:02 PM
bostonc400's Avatar
2023 AMG E53
This happens to me from time to time as well. It's extremely frustrating. It's as if it's stuck down or something. When it's stuck, it won't respond to any gestures.
Old Apr 12, 2015 | 05:10 PM
StanNH's Avatar
2015 C300 Sport: Palladium, Premium, Multimedia, Leather, BLIS
The early builds did have their share of issues. I just traded my August build C300 for a March, 2015 build and the quality has improved over the months. Although I did not have any touchpad issues, some have been reported.
The easiest way to deal with this is to have your dealer order a new unit and just have it replaced under warranty.
Old Apr 12, 2015 | 05:50 PM
DBOC205's Avatar
W205 C250BT
There's definitely a fault. In the C200 loan car I had earlier this year the touch pad had the exact same issue you're describing. I'm pretty sure I've got a video for it somewhere. Seemed to me like something with the upper movable surface against the switch. You can feel that it doesn't actually engage the switch (i.e. the click) because it was stuck in a down position. I found that tapping (quite sharply) all around the upper surface would free it again most times though.
Old Aug 29, 2016 | 06:01 PM
Jay_Chicago's Avatar
2015 Mercedes C300 Sport
Didn't want to resurrect an old thread but I could finally verify this. I left my car 'burning' under the sun for 3 hot sunny days (parked at airport non-covered lot) with no sunshade and with the sun rays coming directly through the sunroof glass (forgot to close the sliding shade) to the top of the touchpad.
When I made it back to the car the interior was so hot that I could barely touch those chromed sides of the touchpad and the sun was hitting on the top of it. The COMAND center wheel knob and all other controls were working fine but the touchpad didn't respond at all.
Once it cooled down, after driving over an hour with max A/C and parked another hour inside my home garage (at 75F) it went back to work.
Old Aug 29, 2016 | 07:18 PM
Shadwell's Avatar
C300 S205 AMG, GLA 45 AMG
Sometimes the little buttons get stuck down, check if its that and pop it back up.. if function returns follow up with dealer for sticking buttons.
If not if is likely a software hangup, try an entertainment system reset by holding down the disc eject button may reset it. If not then go the dealer and have them update the software.
Mine had both, buttons just needed freeing off and haven't repeated the issue, software was updated.
Best of luck.
